Reliable Tachometer
I'm having trouble finding a reliable rev counter.
My setup uses an Aldon ignitor with an Omex Clubman Rev limiter and Lucas Sports coil.
Anyone running this sort of setup, please ?
Stuart.
Stuart.
- stuartgb100
If I use a reliable revcounter, - like a STACK -, I wouldn't see the need for a revlimiter. Throw it away..... The Ignitor or the Lucas coil will not represent any difficulties.
Dag
Dag
Dag-Henning - Third Gear
Hi Dag,
I will look at Stax's range.
The rev limiter is for peace of mind - stuck throttle; missed gear; etc
As ever, thanks for your help.
Stuart.
Stuart.
- stuartgb100
rgh0 wrote:its a brave man with deep pockets who races a twin cam without a rev limiter.
...and not just when racing!
elan-f15/catastrophe-elan-ownership-day-one-t20039.html
Cheers - Richard
- ardee_selby
- never been able to find a reliable, mechanical limiter that allowes 8000....- an electronic one is not allowed acc to App.K .....so, I try to be brave...
Dag
Dag
Hi Dag
I did not realise that electronic rev limiters not allowed in Europe. Here in Australia we have to have points ignition but are allowed a separate electronic rev limiter out of respect for the cost of historic race engines. The original style Lucas mechanical rev lmiiter should be capable of modification for a 8000 rpm cut out with changes to the springs preload used?
What do other competitors use or do you all just look at the Tach closely always and have a hand on the ignition switch continually
Hi Rohan ! - I do believe we all run with a std. rotor without the limiter, but I am not sure......Yes, the original limiter may be modified I guess, either by "looser" springs or by lightening the "fly-out-weight"..??? I have no test-bench for distributors, but I guess it should be possible....I do agree it would be a sensible security messure.....!
Dag
Dag
