Full Roll Cage
PostPost by: stuartgb100 » Wed Sep 01, 2010 6:56 pm
Which (if any) full cages can be fitted to a Sprint, please ?
It has an early Spyder chassis.
I would like to fit side impact protection bars (are these removable ?)
Does it involve removal of the body ?
Stuart.
stuartgb100
PostPost by: batfish » Thu Sep 02, 2010 7:31 am
Stuart
In the UK there are 2 suppliers of roll cages that I know of, Tony Thompson and Kelvedon. Both cages are fitted inside the body which must be on the chassis. You have to cut out a hole in the inside of the rear arches to slide in the side intrusion bars , the holes can then be blanked off with an aluminium plate.
regards
Andy
batfish
PostPost by: Old English White » Thu Sep 02, 2010 9:22 am
Hi ,
Andy's reply was only on homologated roll cages ...
As far as I know , Spyder do its own , and it seems that only this one should be able to cope with your chassis ...
For the front cage , that could be tricky ...
Christian.
Old English White
PostPost by: Steve G » Thu Sep 02, 2010 10:19 am
http://www.spydercars.co.uk/spyder_chas ... r_bars.htm
Don't fit if you're tall/long of leg and need the seats in the further back position. Good quality item, just get them to check the accelerator doesn't foul the footwell bar if you're fitting the SIPS.
Steve G
PostPost by: gav » Thu Sep 02, 2010 10:42 am
Hi Stuart
I am running a Tony Thompson rear and side intrusion bar in my Sprint.
It was tricky to fit but is very snug and doesn't cause a problem with seats or feet (I am 6 feet tall).
I have since changed seats to a pair of leather Elise seats and they present no problem either.
Have fun
Gavin
gav
PostPost by: gav » Thu Sep 02, 2010 10:43 am
Meant to mention, I installed it in situ.
Gavin
gav
