Raising the Final Drive Unit
I am about to begin reinforcing my frame heretofore stock) and am considering raising the final drive by 1/2 inch to reflect the fact that the ride height will be decreased through a fully adjustable suspension. It seems that this would be a good idea, though I've not read of anyone who has modified the frame to accommodate the change. What do you think? Has anyone done this modification?
Jerry
Jerry
- jkolb
Jerry -
You can move the diff up by fitting the TTR mounts instead of the stock units. I have done this on a couple of cars. I also use the diff bracket and make sure the rods that control fore and aft movement are upgraded along with rreinforcing the chassis fixtures for the rod attachment. I run stiffer springs. and I am not looking for long travel with UJ's and sliding splins.
I try to be systematic when I do things like this.
George
George
- cabc26b
I am doing the full 26R reinforcement, and using TTR's uprated mounts. Installed as stock, these mounts do not increase the height of the differential materially with respect to the inner wishbone pivots. It is my understanding that the TTR frame builds in an increase in dif height, and I am trying to accomplish that by shimming up the TTR mounts with 1/2 inch aluminum "pads". This, however, brings the dif into conflict with the rear crossmember. I can do this and reinforce it in a manner that will not reduce its strength, but am looking for some input as to whether this will be helpful. It would seem to reduce the drive shaft angles in a car that is being lowered, but is it material? Is there something I am missing? The car is almost exclusively a track/race car.
Jerry
Jerry
- jkolb
Jerry
How are you intending lowering the car? I get most of the lower ground clearance in my Elan from the smaller diameter 175/60 tyres I use. The suspension has only been lowered a little so that the drive shaft is aproximately horizontal with normal diff location. This produces a ground clearance of about 100mm under the body / chassis and about 50mm under the exhaust which is about as low as practical for me at least.
Even if you lower the suspension substantially further so that you had say a 20 mm rise in the drive shaft from diff to wheel hub I dont believe this would be a problem as all the types of drive shaft join can tolerate normal running at this sort of angular deflection. However lowering the suspension this far starts to limit travel substantially which will affect handling adversly in other ways.
regards
regards
Sorry - my recollection is the mounts I got were shorter than the ones I took off, agree with the nominal lift comment though, espcially when you add the bracket. On the frames Not following you - The ttr frames ( they're done by Miles) don't modify the rear cross member holes -
- cabc26b
