Aluminum bellhousing
Pete,
From the TTR web site the alloy bell housing saves 4.6kg. Negatives? yes the threads strip easier!!!
http://www.tonythompsonracing.co.uk/mainframe.html
- elanman999
And the magnesium bellhousing saves 5.85 kg.
Might as well go whole hog and replace the gearbox case with aluminum (8.2 kg), the differential case with aluminum/magnesium (5.75 kg), and the engine block with aluminum (about 18+ kg).
Then magnesium rear uprights, aluminum flywheel, aluminum front hubs, lightweight calipers, aluminum radiator, aluminum/magnesium wheels, lexan windows, TT lightweight body shell - the possibilities extend onward!
David
1968 36/7988
David
1968 36/7988
msd1107 - Fourth Gear
wellllll its the best $450 I spent on the car - ---I just go and lift the whole tranny bell and marvel at the lack of weight of magnesium ----and its so pretty -and the helicoils prevent thread stripping -- the old bell allowed newspapers- -rocks -small dogs and old people to be sucked into the clutch area causing throw out bearing failure -- -ed
Ed
Well maybe this time you'll fit the closing plate at the bottom or the same foreign objects will continue to be hoovered up....
good idea ---the plate and stiffener plate weighs more than the housing -- ----ed
