Fuel spillage from filler
Si
Still got a smile on my face...
P.S. measure twice/cut once if you don't want to fit it reversed...
Just installed EPA's suggested mod.
Bought an MX5 Mk2 filler on ebay and the suggested reducers.
Cut the end with the valve off the MX5 filler and pushed it into the smaller reducer.
The collar on the smaller reducer is a tight push fit into the pipe on the tank so pushed it in and put the hose back on. Not as professional as John's machined boss but looks like it should work.
Here are the pics.
Now for the test........
Dougal.
Here are the pics.
Dougal.
- dougal9887
Well, filled it brim full and went for a spirited drive. No spillage. Brilliant mod. Thanks EPA.
Dougal.
Dougal.
- dougal9887
My filler pipe takes a 90 degree turn at the bottom unlike those of the pipes pictured by other posters. The hardest part of the whole process was getting the nitrile hose fitted between the 90 degree pipe and the pipe into the fuel tank. There is very little room between the two pipes in which to maneuver the hose into place. I've attached a couple pictures to illustrate the pipes on my '71 Plus 2 S.
I'll have the car back on the road in the next couple weeks and will report back then.
Lee
Jackson, CA
- Harvey
Hi Lee,
well done and the paint on the back Wing will thank you for the mod
- alan.barker
A note of caution here: viewtopic.php?f=40&t=42140
I've still not got round to revisiting this, but I think measurements should be taken of the tank spigot and valve diameter in order to order the correct spacers. In the meantime I achieved a filler cap seal by virtue of a piece of rubber sheet screwed to the cap underside.
JonB - Coveted Fifth Gear
Most modern cars have a second filler "cap", aka a spring load flap, at the top of the neck under the outer cap. There must be possible to find a suitable one of those to use instead of the Mazda part.
For example:
https://www.fillernecksupply.com/2-or-5 ... nj-2-20-f/
For example:
- mbell
sorry but imho.
Why reinvent the Wheel, the Mazda mod works.
But it would be good to see one fitted.
- alan.barker
alan.barker wrote:Why reinvent the Wheel, the Mazda mod works.
Because:
DJW wrote:Managed to buy a second hand filler neck but the one way valves are on back order with no outlook date
And it also fun to figure your own solution.
- mbell
Users browsing this forum: UAB807F and 18 guests
