Elan Plus2 rear seat belts
Jeff, sure someone with an early car can confirm, but I thought they were always installed. I don’t see any mention of rear seat belts being added in the Robinshaw & Ross Plus 2 Production Milestones listing, so assuming they were always there.
I certainly recall folks retrofitting lap belts in the early sixties, but that was often front only as you describe. I did see an online reference that rear belts were not required until the ‘70’s. Seat belt use regulations were much later in the ‘70’s.
Interesting question. Maybe Lotus was ahead of the curve?
If you need to source rear belt mounts and high strength bolts I think Spyder stock them. They are definitely prone to severe corrosion along with the rocker rails.
HTH
Stu in Calgary
HTH
Stu in Calgary
Stu
1969 Plus 2 Federal LHD
Hi There
For the UK at least, I didn't think rear seat belts were ever fitted to the Plus 2 as standard, I don't think there were even any mounting points. In the UK, although the law required front seat belts to be fitted to cars from 1965, the fitting of rear belts wasn't compulsory until 1987.
Andy
Andy
- andyelan
My 1971 S130/4 was a one owner car, and original, moreover I recently removed the rear padded side panels (and in the process the rear seats and parcel shelf) which expose the seat belt mountings: nothing there for rear seatbelts.
You might ask why I took the rear interior apart: to trace a dangling wire in the boot, which turned out to be the live feed to the boot light and belongs in a bullet connector behind the rear pillar..! The joys of lucas bullet connectors..!
TonyA
TonyA
- TonyA
I believe the mounts where a standard factory fit, at least by the time if the s130. I suspect rear belts werent ever fitted by lotus but we're a dealer fit item but nothing too back that up.
As mentioned by Stu the outer plates are in the wheel arches where they are very exposed and rot. I wouldn't fit rear belts with out replacing them.
- mbell
My 68 does not have them. Likely a leftover Federal USA car.
Mounts present, no holes drilled.
Love your Mother
Earth
Love your Mother
Earth
Yes I don't believe that fitting of rear belts was ever standard but in some countries depending on when compulsory seat belt fitting came in, they may have been fitted. Here in Victoria wearing of fitted seat belts became compulsory in 1970 (first place in the world) but fitting of seat belts to every seat on a new car did not become compulsory until later.
Rear mounting points appear to have been included by Lotus in around 1971 with the S130 cars though i am sure like all things Lotus this changeover probably was hit and miss for some time as body shells were used up. My 1973 Plus 2 has them.
My federal '70 has them and the original owner took delivery at the factory, so they were not dealer-installed. Doesn't answer the question for UK cars but it's another data-point.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
My 1973 +2S130/4 had the anchor points but no belts fitted.
- alan.barker
My 1973 s130 did not have them and my present 1971 S130 also does not have them.
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
My old '73 (May) S130/5 had the anchor points but no belts (I had to replace the outer ones as they were rotten when I fitted rear lap belts. Think my current one (July '73) has them too. So I guess they may have started fitting them in Spring '73...?
Craig Elliott - Third Gear
My 1968 +2 did not have them fitted from the factory. I purchased the car in 1986 and there were no mounting points for rear seat belts. I believe they were a dealer option as I bought a complete kit some time in the late 80s or early 90's from Paul Matty. He had a big box full of them.. mounting plates, belts, fitting kit... I wish I'd bought a load as they were the kangol type, exactly as in the parts manual, complete with 1967 sewn on labels.. . I have since fitted them. they are lap belts only, but very suitable for securing a small dog. Spyder used to do a kit to fit diagonal or harness type belts, eg for children. Let me know if you need any photos of the fitment
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
