Pedal box cross shaft
Does anyone know of a supplier of a the cross shaft you find in the pedal box. I think part number A0500J0022. My car is 50/1510 Federal spec, so I think that is the right one. I've looked at the usuals and no one seems to stock them.
- JeffP
My apologies everyone. Post removed.
I don't think I have described my question very well. I'm going to edit my post or post again. I'm referring to the cross shaft that is in the pedal box.
- JeffP
I don't believe it is available as separate part. Its just a length of 1/2" bar with couple of holes for split pins to hold it in place. So should be easy enough to make.
I believe some people get a 13mm bar instead as allows removal of any play due to wear. But probably want to asses what you have before deciding.
- mbell
It's also worth bushing the pedals with some oilite or bronze if you're doing it
- jono
It's also worth drilling/cross drilling the bar ( a la crankshaft ) and fitting a grease nipple in the end.
+1 for John.
I have had the pivot bar rust up in the past and fitted grease nipples.
- alan.barker
Grease nipples are a nice touch but not really necessary if you use stainless bar stock with oilite bushings
- jono
So there you go Jeffp,
Three choices they're all good and better than original. Take your choice.
- alan.barker
Many thanks for the suggestions . I have a local shop who should be able to produce the recommended version quite easily.
- JeffP
