Replace petrol filler cap +2
Hi Guys, do you have any tips on easily removing the petrol filler cap and tube( can the cap be replaced in situ) ? Regards Steve
72 Elan +2S 130/5
- Steve Brooks
Well I would not try to remove the filler cap in situ. You would have to tap the roll pin out, which may or may not be a tight fit, and that would put pressure / knocking on the rubber grommet which is hard up against the body which could induce stress cracks. Must be better to remove the cap and neck as a unit and do the job on the bench.
Leslie
Leslie
- 512BB
Yes, agree with the above. It is not difficult to remove the unit and then tap out the roll pin.
Trevor
1968 Elan +2 50/0173
TeeJay - Fourth Gear
Hi. I would avoid tapping the pin out. I pressed it out and back in again with a vice and small socket plus other spacers - I forget exactly what I used now - I improvised. Tapping it out may result in damage to the chrome - yes ok that's what I did to my new one so had to reinstall the original. I don't think I'd try holding the vice over the car haha.
Incidentally, I did find a jar of sainsbury pesto was perfect for blocking the tube between filler cap and tank
I can supply photo if needed
Regards.
Sean.
Regards.
Sean.
- alaric
And if the tube/neck is out, it's also a good time to renew the gasket between it and the body.
1969/70 Elan Plus 2 (not S) 50/2036
The Veg - Coveted Fifth Gear
