Autosparks harnesses?
Apologies if this is an obvious question, but what’s the difference between autosparks main harnesses and dash harnesses?
https://www.autosparks.co.uk/lotus-elan ... -harness-1
And
https://www.autosparks.co.uk/lotus-elan ... ng-harness
I have a 71 plus 2S (uk car). So assume these looms are suitable?
I’ve just about given up trying to make the loom I got with the car fit as it rarely matches any wiring diagram in the manuals.
Ian
And
Ian
- Doctor924
One goes in the front and the second joins it to feed everything behind the dash. You will need both if you are replacing everything.
This is the first time I have seen the prices of these things. Not cheap, and with the variants of the Elan wiring during its run, there is no guarantee that it will fit straight out of the box - see the numerous other threads on the subject.
Are you au fait with auto-electrics? If so, try making your own harness...
Hal Adams
Evora - the poser
Elan +2 - keeps me busy
Macan - hers
Felicia Pickup - my favourite
Peugeot 207 E85 converted - to battle inflation
Evora - the poser
Macan - hers
HCA - Fourth Gear
Thanks - so the main harness is better described as the engine harness which then connects to the dash harness and the rear harness... No.. - not cheap.
The one that came with the project car I have is a very very poor fit with any wiring diagram I have found, making it very hard to follow and adapt. I have no idea which make/variant the one I have is.
So the risk is even if I were to get a new set of harnesses for my 71S, there is no real guarantee they would be any better?
Ian
Ian
- Doctor924
I've fitted three Autosparks harnesses (2 x Elan type 26 & 1 Elite Mk 14); all three fitted well, though on the Elan looms, an additional coil wire was required.
Mazzini - Coveted Fifth Gear
Doctor924 wrote:So the risk is even if I were to get a new set of harnesses for my 71S, there is no real guarantee they would be any better?
Ian
They would be a lot better
As he says though, it might need a small addition/adjustment.
Hal Adams
Evora - the poser
Macan - hers
Evora - the poser
Macan - hers
HCA - Fourth Gear
They look fairly priced to me.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
They look quite reasonably priced for full wiring looms. Something made properly that should work is much better than trying to make it yourself. You end up with a lot of wires the same colour with tracers on the ends. No fun when it needs fault finding
SimonH - Third Gear
Does your 71 +2S have 3 Fuse Boxes which is important to get correct Harness.
- alan.barker
It came without the old loom so I have no idea.
- Doctor924
Doctor924 wrote:It came without the old loom so I have no idea.
Easy way to tell is if it has a fuse cover in the dash it’s a later single fuse box version.
Ash tray in same spot is 3 fuse box under bonnet type. Mine is an early 130 with the fuses under the bonnet.
SimonH - Third Gear
You should have the Fuse Boxes in Engine Bay nearside or holes where they were fitted. Or as said for
2 S130 fuses where Ashtray used to be in Dashboard.
Big difference on Harness
- alan.barker
Autosparks have been in the business of making Looms for lots of classic cars for a very long time now and they know all the options and variations.They know what they are doing.
I have in the past on other classics also found them very approachable if you have queries. Being local to them I usually visit but do give them a call if you need to.
All the different +2 Loom and fusebox variations are shown on their website.
'71 +2 S130/4
'71 +2 S130/4
- alanr
