Re: Plus 2 restoration
Posted: Sun Jul 03, 2022 1:04 pm
I've run out of excuses to not start the body work. I thought I would start with the trunk lid.
It looks like there were only two coats of paint applied. The original blue and then later a coat of white paint perhaps painted on with a brush . There is also a white primer, grey filler and also red primer between the two coats. The paint has also completely worn off in area, down to the gelcoat.
Questions:
1) Is it safe to prepare the surface and apply primer over multiple paint and filler types or must it be all be taken down to the gelcoat?
2) When repairing cracks with fiberglass mat and resin, must everything be kept below the surface or will high spots of fiberglass be sandable once applied?
Questions:
