VIN and DVLA help
Doors, engines, etc can be changed so not necessarily a good clue. Similarly the chassis number as LR simple refers to Lotus Replacement. Also the VIN plate does not look period, these are readily available new on Ebay and the stamping does not look correct. I suggest that someone has fitted a replacement chassis, possibly in Sweden and used the new chassis number to get it registered and stamped a new VIN plate accordingly.
As others have suggested the dyno tape number is the big clue and suggests the number should be 2711. If you register with Elan Registry you can check all similar chassis numbers close to 2711. I am sure there are experts on here that can point you in the right area wrt to the correct numbers as they do seem a bit bewildering. But maybe to get a close VIN number you will have to look at some similar numbers on Elan Registry and add 2711 to give you something that looks right, such as 710502711. 71 being the year, 050 being the type number and 2711 being the identification number
Incidentally you may find 2711 under the headlining. You may not want to remove the headlining of course!
Elan +2
Elise mk 1
Elise mk 1
- Donels
Geve ,
I see from the sept 2020 auction details it states there is an old MOT and the "original registration documents " https://www.handh.co.uk/auction/lot/304 ... 50979&sd=1
these documents are not mentioned in the second auction,
i suggest you contact H &H auctions and ask for a copy which they should have,
Edit-- https://www.handh.co.uk/auction/lot/304 ... 50979&sd=1
50/0024
- steveh
Thanks everyone
Yes, i did take the headling down, but no numbers ?
I have called H and H auctions, but they told me the car was never physically with them, they sent someone to photograph it. When i looked, i did not see the picture of the documents, which proves the buyer at the time did have them. The buyer is the one I bought the car from. I have been in touch with him through the auction and he has never indicated he has any paperwork. I will now go back to him and ask again. Begs the question what reason to withhold them ?
There is a registration number of CUR 812 ?
Maybe worth checking with DVLA
Andy from Lotus told me i should be looking for a VIN number with 4 numbers and a letter ? But, if it is a 1971 car then surely it should be the 70000000 format.
- Geve
Please, I have written an article on Lotus VIN and other numbers which is attached to my first response to this post.
There is a lot of guessing and speculation as well as misinformation confusing this issue on this car. It is all explained in the article.
I have reached out to the owner Grant and have offered to assist him privately.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
As Tim says, the article clearly shows what format the VIN should be for a specific car and year. Best of luck dealing with DVLA, not the most helpful bunch of people in the country, We had the same issue with a car imported from South Africa. Never again!.
- jasper2347
Tim, I've read your note and offer some information relating to 1972 +2 130's. Attached is a picture of my original VIN plate, plus pictures of the numbers marked on the roof and transmission tunnel, which all relate to the dyno marking in the engine bay and to the VIN plate.
I have no idea when Lotus started using this but it’s all very logical.
Dave
Dave
Elan +2
Elise mk 1
Elise mk 1
- Donels
I may be wrong but I've not read the following advice yet.
ie
Do Not ! ,
Never , Ever !
Inform, the DVLA that you have changed your chassis !
Possibly ' one of ' the reasons why you have been offered a Q plate ?
ie
Do Not ! ,
Never , Ever !
- greg40green
Hi i still have the paperwork for a 1972 +2 It is sorned.I had 2 made 1only
Paperwork available if you are interested
- pete.chiswell
Users browsing this forum: alan.barker and 20 guests
