Lotus Elan
Headliner colour
PostPost by: bexylou » Sun Jan 17, 2021 1:39 pm
I intend to paint/dye my headlining on my +2. 1968 The colour looks off white, does anyone know if there is a specific colour code or name that I can quote.
Thanks Tony
bexylou
New-tral
PostPost by: mikealdren » Sun Jan 17, 2021 2:20 pm
Are you planning to do it in situ? I can't really see a painted headlining looing good. If it's in bad shape, I think you'd be better off replacing it.
mikealdren
PostPost by: bexylou » Sun Jan 17, 2021 8:06 pm
I do plan to do it in situ, its not bad at all ,but the "A"
posts are very stained/yellow and wont clean up, I have seen leather dye being applied to seats with a cloth and thats what I want to do, but not sure what colour it should be . It looks "off White" but wondered if there is a name ,ie old English white?
Thanks Tony
bexylou
New-tral
PostPost by: EPC 394J » Sun Jan 17, 2021 8:55 pm
I think there are some good results from others if you search the forum?
Where, then, lies the answer? In choice. Which shall it be: bankruptcy of purse or bankruptcy of life?
Plus 2S
BLL 315H in white.
EPC 394J
PostPost by: stugilmour » Tue Jan 26, 2021 8:05 pm
Not sure if this is a help, but I used Dupli-Color Vinyl and Fabric spray paint to touch up the sun visors. The available Gloss White matched pretty well with the new headlining material I got from Sue Miller. The old headlining had yellowed considerably when compared to the new material, so expect matching to your existing headlining might be a challenge. I expect two cans of Dupli-Color would do the whole roof though. If planning on coating the entire headliner I would recommend removing the C pillar panels to do separately. I think the rest could be effectively masked and the door seals pulled down to prevent overspray.
The white finish has been reasonably durable; much more durable than a similar black product I used for the carpeted areas of the door panels.
https://www.duplicolor.com/product/viny ... c-coating/
HTH
Stu
1969 Plus 2 Federal LHD
