How high do I need to lift the body?
PostPost by: GLB » Wed Jan 06, 2021 10:06 pm
I had removed and cleaned the side sills. Being a desert car the sills and chassis were not rusted, just dusty and in need of new paint. The support visible in front of my friend was to support the roof truss near chain hoist but I don't think it was really needed. Just cautious. Body was bare, nothing but sills. Gary
GLB
PostPost by: dcmarsh » Thu Jan 07, 2021 12:58 pm
Gary, great idea and pix. Would not have thought the bobbins could support the pull upward! Thanks. Dave
1971 Elan +2S
1975 Elite 503
2005 Elise
1991 M100 (sold, regretfully)
dcmarsh
First Gear
First Gear
PostPost by: danbuoy1 » Fri Jan 08, 2021 9:08 pm
Checked and about 6'6"' (78") between garage floor and roof at rear, so based on answers (thanks) I should just about have clearance altho was planning on using a wooden frame with couple of manual wire hoists which will eat into it. I need to sort out rotisserie for other shell first to gain width for Elan sill work.
Cheers for help!
Paul
danbuoy1
PostPost by: 3261R » Sun Jan 10, 2021 6:56 pm
Just done mine. 34.5 inches. with wheels on and Dunlop SP tires. Jon.
3261R
New-tral
PostPost by: danbuoy1 » Sun Jan 10, 2021 7:03 pm
Is that 34.5" extra height needed abovethe top of body?
danbuoy1
PostPost by: 3261R » Mon Jan 11, 2021 3:57 pm
Sorry to be ambiguous.
I have removed my bodyshell and I measured from the floor to the highest point of the rear shock tower with the wheels on. If you are critical for headroom you could remove the wheels, put skids under the hubs and pull the frame out. If you have the space to pull it out sideway would require even less headroom. The difference is on account of the transverse tunnel over the rear axle in the body tub.
Just been out and looked at my frame and the body. To do a sideways move you might be able to get away with little over a foot - to do it fore & aft about two feet. (34.5" minus 6" +/- ground clearance of the body). The front end doesn't look so critical.
Let me know if you need more dimensions.
Jon.
3261R
New-tral
Previous
