How many rpm at 60 mph
Need to know what differential ratio, tire size. Assuming 4th gear (1.0).
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
I ended up buying:
https://www.amazon.com/Maintenance-Tach ... 07PMJH7QV/
For a reference while adjusting my spyidia converted tacho. Simply wrap the lead around the coil wire and you have a reference tacho.
The tacho tend to be of by different amounts at different rev so this can let you map it out across the range.
- mbell
Assuming
Stock 165/80R13 tires
Fourth gear 1:1
Final drive 3.78
Approximately 3,200 RPM at 60 mph
With the optional 3.54 Final Drive
Approximately 3,000 RPM at 60 mph
This tool is a very easy spreadsheet to get engine speed in the other gears, change tire size, etc. I just picked the engine RPM off the graph, so plus minus a bit.
http://westfield-world.com/gearboxshifts.html
HTH
Fourth gear 1:1
Final drive 3.78
HTH
Stu
1969 Plus 2 Federal LHD
mbell wrote:I ended up buying:
Has the battery runout (died) yet? Does it log data? Or are you simply useing it for a specified time and gathering results?
Love your Mother
Earth
Love your Mother
Earth
Thanks for this. I have just ordered one from Amazon in the UK. I have an old Fluke digital frequency meter that I have used in the past, but it is mains powered and a major pain to use balanced on the engine. For those who would like one of their own:
https://www.amazon.co.uk/gp/product/B07XYLXXQP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Lotus 50 wrote:I think my tach reads too high. How many rpm is 60? 70?
The Smiths tachometers are a 'best guess' device, and the guess gets less accurate as time goes by and the components begin to fail. The same is true of the speedo, so unless you are using a GPS app for speed, the chances are you are comparing two wrong numbers.
As pointed out above, even a properly calibrated Smiths tach is only correct at the calibration point, it will not be accurate for the entire rev range. To add to the fun, the moving parts in the tach have mass, and cornering forces will move the needle around by a few hundred RPM, depending on where the needle is pointing to start with and how hard you corner.
Modern tachs have given up on all this analogue needle waving business and use a micro controller with a stepper motor drive to the needle, which gets the display spot on. You can buy a period looking stepper tach if accuracy matters (in racing for example) but they don't match the original Smiths tach found in the Elan.
If you want to have a go at calibrating or rebuilding the tach, it is very straight forward with some very basic skills. There are two different types of Smiths tach, but the many 'how to' guides on the web explain this and how to go about working on them. I came across this guy on Youtube who does a good job of explaining how the tach works and how to repair / calibrate. There are less 'techy' versions available, but I liked this guy's approach, and he seemed to be using a proper camera setup for the video which made it very clear.
https://www.youtube.com/watch?v=w5auLGtzTqY
Good luck.
32 Standard 12
32 Standard 12
- Andy8421
h20hamelan wrote:Has the battery runout (died) yet?
Nope, think it's been in the car 6-9 months. Battery should last a few years and can be replaced in the one I got.
h20hamelan wrote:Does it log data?
No. It's just displays engine rpm and tracks engine hours.
- mbell
Lotus 50 wrote:I assume 3.77 gears. If I believe the tach it would be 4 something. The speedometer is perfect at 62 mph per cell phone GPS. 186/70-13 Sprint Classic tires. Perhaps wider then they need to be but they look skinny by today’s standards
I assume you meant 185/70 not 186/70 (typo)
With your specifications, looks like ~3200 at 60mph and ~3750 @ 70mph:
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Users browsing this forum: GLB and 22 guests
