My Burgundi Elan plus 2 from 1968 to be restored : Sven
• Page 3 of 4 • 1, 2, 3, 4
rgh0 wrote:Newsax wrote:Geoff wrote:Hi, welcome to Elan ownership,I have just finished restoring an Elan S4 and I also live in Belgium
I am at the coast in Bredene. If you live nearby I can come and have a look and help out if needed
cheers Geoff.
I'm more on the south side near Mons,
Any help is welcome, but a bit far away I'm afraid .
But I took not eof it
There is nothing in Belgium that is to far away from any other part of Belgium, that is if you come from Australia.
Well noted
- Newsax
Hi Newsax,
i suggest you replace the Side Members before you lift the Body off the Chassis. New Side members will help support the Body and stop too much movement when lifting.
Get Stainless side Members to do job only once.
To remove old side Members you only need to remove rear Wheel and support under Chapman Strut.
Go along join in Sill with a Hacksaw Blade, then vacuum up the pile of rust dust on floor
SJS have Stainless Steel Sills.
- alan.barker
alan.barker wrote:Hi Newsax,
Go along join in Sill with a Hacksaw Blade, then vacuum up the pile of rust dust on floor![]()
Thanks, that was indeed my plan
Will by side members from Spyder probably.
What is "support under Chapman Strut" ?
Would you have a drawing for "Go along join in Sill with a Hacksaw Blade" ?
- Newsax
HI there,
Finally got my hand on a Lotus Elan +2 chassis/subframe from 1968 totally refurbished and ready to use (with 26R type reinforcement)
with some others pieces I still need to sort out
( more pictures to come later) :
Non exhaustive list :
- Sill member (galvanized)
- Wiring Loom (front, dash and rear)
- Front suspensions (mainly refurbished)
- rear suspension (new)
- Half shaft
- Lotus Elan original steering Wheel (to refurb)
- All around refurbubished calipper
So next steps when I have time :
1) Change sill members (rust powder form) by new galvanized one (from spyder)
2) remove all necessary to detache shell from old rusty subframe
3) start to dismantle step by step and refurbish if needed and reattache to new subframe …
At least it's the plan
This will definitely take ages for my first restauration, but is a good start I beleive
- Half shaft
- Newsax
Whow!...very well done, nice find.
You have managed to find some very nice and useful bits and pieces that will certainly help your restoration along.
'71 +2 S130/4
'71 +2 S130/4
- alanr
Support under Chapman Strut is put a Scissor Jack under to support Car.
- alan.barker
alan.barker wrote:Support under Chapman Strut is put a Scissor Jack under to support Car.
Thanks for the answer, I'm indeed struggling to find where to put the jack (as the current subframe is rotten) while changing the sill member.
Still need to figure out what's the best way… probably using a solid plank to allow maximum repartition of Weight ? without damaging actual rotten subframe and even less the shell
- Newsax
Yes, solid Plank to spread load maxi.
I prefer the Stainless Sills also because when you drill for the Screws along the bottom there is no untreated metal in the Holes.
With the Scissor Jack under the Chapman Strut the new Sill will slide in from the back with a little help
. I put stainless Screws along the bottom also.
For the replacement Dustshields you can make your own from sheet alloy using Snips. Then go around the join with Body with a Silicone Gun.
Have fun
Have fun
- alan.barker
alan.barker wrote:Yes, solid Plank to spread load maxi.
With the Scissor Jack under the Chapman Strut the new Sill will slide in from the back with a little help![]()
Have fun
Mine are galvanized from Spyder, will carefully drill those holes and make sure no metal particule are left.
What dimension of screw have you used for the bottom ? they are attached to a nut or you can make treated hole ?
Ok will try to put jack under chapman strut then if it can help to put new sills in
I have new dust shield ready, but was not knowing that they were only glued by silicone, was Believing they were attached somewhat (diffucult to say with the rusted one on there at the moment
- Newsax
Sorry i meant to say fix Dust Shield with self tappers. The Ssilicone is to seal around the edges
- alan.barker
From manual I see the following (so screw with nuts for sill, an djust screw for backing plate) :
2 050B0003 1 Reinforcing Member - LH
050B0002 1 Reinforcing Member - RH
FUFS1012 22 Screw, Reinforcing Member to Body
YUFN100F 22 Nut, Reinforcing Member to Body
A03W0605 44 Washer, Reinforcing Member to Body
050B1235 4 Backing Plate - Plain
050B1236 2 Backing Plate - Seat Belt
XUFS0412 24 Screw, Backing Plate Fixings
L04W0000 24 Washer, Backing Plate Fixings
050B1271 2 Dust Shield - Wheel Arch - Front
PSTS0608 20 Screw - Dust Shields to Body
Do you know where I can find the dimensions/caracteristics of those ?
I bought a pack from eBay ( https://www.befr.ebay.be/itm/LOTUS-ELAN ... 2749.l2649 )
Are they in this pack ?
1/4 UNF X 1/2, 1/4 UNF X 3/4, 1/4 UNF X 1,
5/16 UNF X 3/4, 5/16 UNF X 1, 5/16 UNF X 1 1/4,
3/8 UNF X 3/4, 3/8 UNF X 1, 3/8 UNF X 1 1/4,
SPRING WASHERS - 1/4, 5/16, 3/8
HEAVY WASHERS - 1/4, 5/16, 3/8
NYLOCS - 1/4, 5/16, 3/8
FULL NUTS - 1/4, 5/16, 3/8
- Newsax
Newsax wrote:From manual I see the following (so screw with nuts for sill, an djust screw for backing plate) :
Found the answer myself
But not sure if they are the right one ?? (sound quite large for the sills ?)
So : Sill below screw : FUFS1012 Screw, Reinforcing Member to Body : (nyloc nut and anti shaking washer)
F --> ??
UF --> UNF
S --> Screw
10 --> 10/16 inch diameter (5/8) --> thats large ????
12 --> 12/16 inch Long (3/4)
XUFS0412 Screw, Backing Plate Fixings
X --> Hexognal
UF --> UNF
S --> Screw
04 --> 4/16 inch diameter (1/4)
No mention of self typing (ST) nor any nuts ??
- Newsax
Have fun
This is not an issue. Galvanizing is a sacrificial coating
If you. for instance use a galvanized bolt on a bare steel sheet, it will create a little rust free zone around it.
The material in the hole may have a haze of rust but will not become rot
35 years with spyder sills
I do think the stainless ones are cool looking
- gus
Gus,
as you like and there is more than one way to skin a chat.
If you don't mind me asking, how do you know your spyder Sills are still ok.
Have you removed the Dustshields to check them out or used a flexible mini Camera.
- alan.barker
Hello All,
As mentionned at the beginning of this topics, the carbs on the TC are not the appropriates ones.
I have so found second hand 151 and bought full jetting for a Elan +2 (thanks to this site
I now just need to find time to take care of Sven ...
- Newsax
