+2 headlamp bobbin replacement
Why replace when you can fit a Helicoil.
- alan.barker
Alan, I have the same problem, and with my bonnet bobbins. Can you (or anyone else) advise which helicoils (size) are required please? And how to fit? Drill out first or just wind into the holes as-is? Sorry, don't know much about these miracle things.
JonB - Coveted Fifth Gear
You need to buy a Helicoil Kit which contains: Pilot Drill, Helicoil Tap, Inserting Tool, Helicoils of different lengths.
Or you could go for a Keyed Insert which a solid stainless Insert with Keyways that lock it in place once it has been screwed into the hole.
The Keyed Insert would be better in a position as on Bonnet Hinge/pivot.
- alan.barker
1/4-20 TPI . Just make sure you keep the drill and tap square to the surface and in line w/ the opposite bobbin
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Personal preference is EZ Loks. No weird sized taps or tools. Install with a big flathead screwdriver. The make stainless ones as well.
https://www.ezlok.com/ezlok-insert-319-4
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
JonB wrote:Can you (or anyone else) advise which helicoils (size) are required please? And how to fit? Drill out first or just wind into the holes as-is? Sorry, don't know much about these miracle things.
Jon, you're just being plain lazy here, have you not tried Google or Youtube?
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
I think I had one bobbin that was stripped. The other side was still OK. Thinking I replaced with a hex screw with a nyloc bolt on the end? You could perhaps try it first? One side needs to be threaded though to maintain the spacing of the pod from the main fibreglass body.
HTH
Stu
HTH
Stu
Stu
1969 Plus 2 Federal LHD
pharriso wrote:JonB wrote:Can you (or anyone else) advise which helicoils (size) are required please? And how to fit? Drill out first or just wind into the holes as-is? Sorry, don't know much about these miracle things.
Errr.... busted!
But I don’t know what size I need though!
Users browsing this forum: bitsobrits, elanner and 20 guests
