Gearbox advice
Now that the end of our farther sone 26R project is dawning. I am beginning to collect parts for my plus 2.
I have been told that my car was an s130 but I am not sure if it was a 4 or 5. I ideally want a 5 speed box as I will be using it daily (or frequently anyway). I would therefore like to know which box would be best. I have heard that the lotus box is very bad but what do experts say? There is a 5 speed 2000e box, is that any good?
Best regards, P
Best regards, P
Peter James Evans
1965 Elan S2 (Early 26R replica)
2001 Citroen Saxo Hill Climb Car
2004 Mini R52
2004 Mini R52
- Elan Peter
Hi Peter
Nothing wrong with the Lotus 5 speed in an Elan. OK, it has some parts from the Maxi in it but it's fine up to 160BHP (so I read). I think more than that and you are pushing its capabilities. The gearshift is often complained about but you can fix that easily enough, with a little bit of the old "Vince Reynard Magic":
viewtopic.php?t=45077&p=321531
The only problem is the price premium these original boxes command.
JonB - Coveted Fifth Gear
Tell me about it, I was speaking to a pal the other day (Yes I do have friends ), he said that a decent one would fetch around ?1 500 and for that, I would expect perfection. I think that the 2000E is the best and now I have found a 5 speed, it is probably the route I will go down. I often found with my s3 that it was difficult to get into gear as it was a snappy box, either in or out and that made a quick change very difficult.
Best regards, P
Best regards, P
Peter James Evans
2004 Mini R52
2004 Mini R52
- Elan Peter
Peter if you are after an overdriven 5th gear i would check the ratio's on the 5 speed 2000E as the one I've seen was for racing with a 1:1 5th gear
Ian
Ian
- elansprint
Ok, I'll look into it.
My other option is to put Ford Mk9 box in it which is five speed. The only alteration to the shell would be to move the the hole for the lever back about 3 inches (apparently), that would perhaps be an easy alternative to the Lotus 5 speed.
Best regards, P
Best regards, P
Peter James Evans
2004 Mini R52
2004 Mini R52
- Elan Peter
When you say not cheap, how expensive is not cheap? I am sure it can't be any worse than the shock I had when I found out that the cost of a carrell break light was for one side only https://classicalfa.com/lt068-1-complet ... N6xs2YHoVc
If it's too much, I think I can live with the selector in the wrong place...
Best regards, P
Best regards, P
Peter James Evans
2004 Mini R52
2004 Mini R52
- Elan Peter
Yep, I can live with a hole being in the wrong place.
Best regards, P
Best regards, P
Peter James Evans
2004 Mini R52
2004 Mini R52
- Elan Peter
Peter
Despite the cost, the advantage of a Voight 5 speed T9 conversion g/b is the range of gear sets available from BGH Geartech and their uprated synchro baulk rings and bearings.
http://www.bghgeartech.co.uk/html/gear_kits.html
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Thank you Malcolm, I will look into it.
Best regards, P
Best regards, P
Peter James Evans
2004 Mini R52
2004 Mini R52
- Elan Peter
Just a point, as I understand it, the Voigts 5 speed gearbox assembly is ?2500.00 plus VAT if you are a private buyer and in the UK, therefore ?3000.00.
It does include a complete new clutch assembly with a concentric slave cylinder, new tail shaft yoke and even every screw you will need. That is, everything between the flywheel and the prop shaft.
The next problem is the waiting list.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
When you put it like that, it does not sound bad, I would imagine that once you have priced up a gear box rebuild and bought all of the required fittings (which I do not have anyway) it would probably be similar in price.
I'll see what the budget allows once the 26R is finished.
Best regards, P
Best regards, P
Peter James Evans
2004 Mini R52
2004 Mini R52
- Elan Peter
Do you need to source an appropriate T9 gearbox (there are different variations) for Voights plus the ?2500 + vat or is the cost as outright purchase?
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
It is complete and ready for fitting.
New cast aluminium bellhousing, new clutch assembly, rebuilt gearbox, new aluminium tailshaft casting and yoke.
All screws, and even wire if you have a reversing switch.
Search for `Elan 5 speed conversion` and you should find it.
I have not got one myself but I saw them when they were overhauling my diff. and I was impressed.
I know Mark (son of) as he sometimes comes to our local Club Lotus meetings.
Eric in Burnley
Eric in Burnley
- ericbushby
