Lotus Elan
Early +2 seat back fitting
PostPost by: Baggy2 » Mon Oct 21, 2019 3:32 pm
SEAT BACK FITTING.pdf
(714.71 KiB) Downloaded 180 times
Hello All
I am about to get my '68 +2 seats re-upholstered. The rear panel is held on with metal fittings as shown in the attached photo. I have two questions.
1) How do I get them out without too much damage ?
2) Does anyone know of a source for these fittings?
Many thanks
Baggy
Baggy2
PostPost by: pharriso » Mon Oct 21, 2019 5:36 pm
Looks like a plastic rivet, can you push the centre pin in, then pull the rivet body out?
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Baggy2 » Mon Oct 21, 2019 8:31 pm
Thanks Phil but its not a plastic rivet - they are metal and it looks like quite a hard metal. I guess I could still try pushing the centre pin through and see what happens..?
I see quite a few modern fixings that all seem to be plastic but I've not seen a metal one like these elsewhere.
Thanks again
Baggy
Baggy2
PostPost by: stugilmour » Wed Oct 23, 2019 3:41 pm
Baggy, I thought my car (?69 Federal) had plastic rivets that look awfully similar. I removed them by pushing the centre stud through with a wire or pick. Unfortunately the little studs can get lost in the process. I purchased dimentional plastic rod from the local hobby shop to make up replacement studs.
About 1/3 of the fasteners got damaged during the whole process. Have replaced with non stock ?tree? type fasteners. Have it on the list to source correct looking replacements but have not done it yet. Will take a look today. Let us know if you find something. Bet Susan Miller may have something?
EDIT
Found these by Dorman that look similar to the plastic ones on my car. Have not checked dimensions, but they probably come in different sizes.
Dorman AutoGrade Rivet
Part # 961-069 Line: DOR
https://www.oreillyauto.com/detail/b/do ... alt?pos=81
HTH
Stu
Stu
1969 Plus 2 Federal LHD
PostPost by: George S L » Thu Oct 24, 2019 6:26 pm
Hi Baggy have you tried woolies
: [email protected]
George S L
New-tral
PostPost by: Baggy2 » Thu Oct 24, 2019 10:50 pm
OK guys - red face time ! They are plastic rivets !
Having poked them with a screw driver I was totally convinced they were metallic.
Knocked the centre pin through and lo and behold out comes a plastic rivet ,
I feel a right twit,,,,,,,,,
Thanks for all your suggestions.
Baggy
Baggy2
PostPost by: The Veg » Thu Oct 24, 2019 10:52 pm
I think anybody who owns a Lotus for any length of time has a certain amount of twit in them (I know I sure do!). You're in good company! :lol:
1969/70 Elan Plus 2 (not S) 50/2036
The Veg
PostPost by: mbell » Fri Oct 25, 2019 8:19 am
Just to say thanks for the info. Last job in my driver's seat repairs is to sort the rear cover out. So useful to know the type of father originally used.
Users browsing this forum: bill griffiths and 18 guests
