Glove box won't open
Hi All
Wonder if anyone can offer kind advice on how to get into an otherwise seemingly unopenable glove box (UK 1972 Plus2 S130) No matter how much it it pressed, it will not unlatch.
Any known work arounds please?
Thanks in advance
Thanks in advance
1963 Nuffield 460
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
Andrewelan - Second Gear
Thanks. Worth a try...now to root under the sink to see where the plunger may be....
1963 Nuffield 460
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
Is there inward movement when you press the glovebox? The latch mechanism can become sticky and not release, or the body of the latch can be dislodged or become loose making it difficult to allow enough travel for the mechanism to operate. If it?s stuck on the closed function it really won?t release by pulling the door, these types of latch are often used for quite heavy loft access panels so they are tough old things that don?t easily pry open if forced.
This is the item, it?s a sprung loaded mechanism. It may be possible to use a spray penetrating oil with a tube like those WD40 cans have. Give a good squirt, leave a few minutes then give the glovebox door a firm sharp push with the heel of your hand a few times, normally this will do the trick
Kindest regards
Alan Thomas
Alan Thomas
Thanks for further suggestions folks and confirmation that the latch is the same as my old S4. Will give all the above a whirl!
1963 Nuffield 460
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
I had a lot of trouble with mine, it was stuck shut from when I bought it at auction.
Ended up unscrewing it from the back of the dash. The wads of cash and comprehensive history I was hoping for weren't there - just a crusty old chamois
Elan +2 #0245
Exige S2 Supercharged
Elan +2 #0245
- Chrispy
ooh I like the magnet catch idea Thanks
1963 Nuffield 460
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
Users browsing this forum: Mike133 and 21 guests
