Overheating - Help!!
Thanks again.
I know I come across as a complete beginner (because I am!!) but how many of these do I need and is there any tips or pictures for where I actually place the foam??
- Pointshape
Re the bottom card thing. I have made them in the past. A piece of thin flexy alloy sheet from B& Q. Fashion a bit of a curve on it and cut to shape to slide underthe rad bottom tank. Spray black and fit a strip of seal strip on top surface were it fits under the bottom rad tank to prevent rattle. Secure with two self tappers with penny washers into factory holes for original.
Bobs your Uncle.
Only seen bought on once. Seems very easy to break and susceptible to the wet.
Bobs your Uncle.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Home-made foam in place (shaped to suit )..
EDIT..if you look carefully you can also see the shaped foam pieces stuck to the inner wings...all the air coming in from the front went through the radiator...
miked wrote:Re the bottom card thing. I have made them in the past. A piece of thin flexy alloy sheet from B& Q. Fashion a bit of a curve on it and cut to shape to slide underthe rad bottom tank. Spray black and fit a strip of seal strip on top surface were it fits under the bottom rad tank to prevent rattle. Secure with two self tappers with penny washers into factory holes for original.
Bobs your Uncle.
Sue Miller sells GRP ones... inexpensive & impervious to fluids...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
If I remember correctly I made mine from an old polythene oil drum,weatherproof and flexible...just snaps into place in the ridge at the bottom of the radiator and behind the f/glass lip at the bottom.
Posted a picture of my air blocking and water rail to my original post.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Users browsing this forum: pdenton26 and 17 guests
