Late S screen
Sun Jan 27, 2019 9:22 am
by jasper2347
Hi all, has anyone used the SJ Sportscars fitting for the late model S cars? They reckon the early cars have a rubber and chrome trim which bonds in which they also supply, but the later cars, 74 on only have a plastic chrome trim and no rubber at all, which holds the screen (part no SJ603) and this bonds straight to the car as a modern car does. Two corners are then supplied (part no SJ556) to finish the job. Out of interest, our new screen does sit in the recess where you would expect a new type car screen to fit, rather than leaving space for any rubber. Just interested if anyone has used these parts before purchase.
Cheers, Rob
Re: Late S screen
Mon Jan 28, 2019 4:40 pm
by jasper2347
Further to the post. I have now confirmed with Lotus this is the correct screen fitting trim and that the screen does bond straight to the car with no additional rubber using a modern adhesive. If anyone has any interest I can post a photo record of the fitting process when we eventually get round to fitting it.
Soon be spring and we can get out in our cars.
Re: Late S screen
Mon Jan 28, 2019 8:15 pm
by JimE
Whenever the bonded in front screen on my +2 and Europa have needed changing, I have left it to the experts (Lotus Cars and Morland Jones). I'm sure readers will be interested to see how you get on. I believe it's tricky to get it right. You'll need to take care with the plastic trim too which can wrinkle in the top corners. Probably best to do this job on a warm day. I haven't looked to see if there is a thread on this but check first to avoid any pitfalls. Jim
Re: Late S screen
Tue Jan 29, 2019 3:26 pm
by Hawksfield
Jasper
I too would like to see this method of fitting the screen in photo views
Thanks in anticipation
Re: Late S screen
Tue Jan 29, 2019 5:23 pm
by Bud English
Not too many photos, but this post by Dougal describes the process and materials he used. It's the best info I've seen posted. Now a good YouTube video would be most helpful either as a how to or a how not to guide. Want to give it a go?
lotus-chassis-f36/bonded-windscreen-t35507.html#p243025
Re: Late S screen
Wed Jan 30, 2019 7:03 pm
by jasper2347
We've done plenty of modern bond in screens on resto's so I think we will have a go with this once we get started with it. I know in the old days of plastic Mini trim round the arches and roof, we used to use hot water to soak the plastic before fitting. In these days of heat guns etc. these may be a better option for the curves without wrinkles? We will see shortly. In the meantime will have a look at the suggested posts. Many thanks for your info.
Re: Late S screen
Wed Jan 30, 2019 7:25 pm
by Mick6186
Rob,
I have just finished installing the bonded screen on my elan+2 130/5. It is a horrible messy job and nothing like a modern bonded screen fitting. The plastic trim has to be bonded to the screen first and preventing crinkles in the top corners is not easy (I have them). The process is much easier if you can heat your workshop to heatwave levels because the plastic becomes much easier to bend. Don't use a heat gun, just a hairdryer. The corner pieces supplied by PM are not the correct profile and have to be 'fettled' which is harder than it sounds. With the trim on it's not a simple task to get the screen central in the body and ensure it contacts the bonding agent all round. I pulled my screen in using ratchet straps with protection where they contact the surround. I intend to inject bonding agent fron inside the car to ensure it is waterproof.
Good luck
Mick
