Metallic rattle
This rattle could come from the vacuum non return valve and be associated with a failure of the servo.
- Terrydales
Hi all
Quick update. I took the car around to a generous and knowledgeable club members workshop today and put the car on a hoist. We concluded the noise is probably coming from the gearbox which is a concern.
Further investigation required prior to anything drastic like pulling out the gearbox.
Andy
Andy
- andyhay
Andy,
I have chased several gearbox noises on a plus 2. Not that it is different than an Elan.
The tunnel and bellhousing making a sound box that can fox the exact ID.
Worst was the needle roller between the first motion shaft and main shaft broken up in the cage. Found in many gearboxes i have bought for parts. Engine out twice for this one. Sounded like bell housing. Also shitty copy thrust bearing (doing the rounds) spinning on carrier on one car. Then i had a noise on a mates car which was the input shaft bearing shield adrift and tinkling.
Re: detent springs, i have shimmed these many times for a more positive snick. I personally can't see how these could make noise. Whilst the spring compress and weaken, I can't see it possible to squash so much. I have lots of them and measure for the longest if building a box. They only differ by about 20 thou at most. Others may disagree. Al will know as he has done lots.
As a point of fact, even new springs from TTR don't measure up to the spec in the manual. They are shorter. I have shimmed those with little alloy slugs punched out with a leather punch.
If/when you bite the bullet and pull the engine there are a few suggestions to look at. I will usually enter a box if i have gone to the trouble of taking the engine out. Especially after the needle roller business and second engine out time. I even changed a clutch plate on that occasion after suggestions it was the plate springs. It was not.
Cheers Mike
Cheers Mike
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Have done the shimming of the dent springs, and stretching the springs as well. Stretching seems to work just as well and takes less time. Slipped a small screwdriver between the coils and bent the spring sideways over the screwdriver blade. Alternating the bending motion keeps the spring straight, while working from one end to the other.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
If the oil level is very low, the gearbox will be very noisy with the engine idling.
Before you pull the engine and gearbox, first try checking the oil level by removing the square plug on the side of the case. Stick your finger in the opening and feel for a level. Fill if required and drive it to see how it sounds.
Dan
Dan
My drive train noise is the same as Richard J's noise, only louder. I can't attach video because the one minute recording must be too large. It occurs on overrun in all gears but is most prominent in 4th from about 4,000 down to 3,000 rpm. It cannot be duplicated on jack stands only when car is on the road. Depressing the clutch will silence the noise.
I've been chasing this noise for a couple years with multiple engine/gearbox out/in exercises. I've replaced almost everything in the drive train except the diff. All ball bearings in the gearbox have been replaced. The noise issues from forward of the gear change lever. Fitting stronger springs on top of the gearbox made no difference. I've even scrapped the original clutch slave cylinder and release arm lash up to T/O bearing in favor of a concentric hydraulic clutch release bearing from Tilton but, again, no difference. Clutch friction disk and pressure plate are new.
A local shop which does gearbox work believes that noise is coming from excessive end float to either gearbox shafts or gears and is preparing to strip down the box. I will report back after I get box back in car and can say that the noise is gone and let the forum know what was done to get rid of this annoying chatter on overrun.
Lee
Lee
Jackson, CA
- Harvey
Hi Lee
It will be great to hear if you can find the cause. I had missed Richard j?s recording - just had a listen. Very similar to my sound - mine is more subtle but that could be because of all the sound insulation on my car. It?s somewhat reassuring to know you have been driving with the noise for some time and the gearbox hasn?t exploded!
Thanks and keep us posted.
Andy
Andy
- andyhay
Another observation from a drive today. The noise occurred consistently driving along in third whenever I placed gentle pressure on the clutch ( not pushing the clutch in fully - just a little) and then lifted off. It lasts about a second.
Otherwise it?s very intermittent. I can drive for 5 minutes with no noise then it come back.
It happens under acceleration and off.
Andy
Andy
- andyhay
Hi Andy
If you are just putting pressure on the clutch release bearing but not disengaging the clutch fully then it sounds like something loose in the bearing itself or the lever arm that holds it which rattles when the bearing sees a little pressure.
Push back the clutch fork gaitor and have a good look inside at the clutch fork and bearing using a torch or inspection camera. Did you check your bellhousing bolt tightness and ensure the dowels are fitted?
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Harvey wrote:My drive train noise is the same as Richard J's noise, only louder. I can't attach video because the one minute recording must be too large. It occurs on overrun in all gears but is most prominent in 4th from about 4,000 down to 3,000 rpm. It cannot be duplicated on jack stands only when car is on the road. Depressing the clutch will silence the noise.
Lee
Hi Lee
May be the rattle come from countershaft. See rattle marks on shaft case and shims:
Cheers Urs
ElanDNA - Second Gear
I've had cars with worn countershafts. Usually what happens is the gears drop out of alignment so you will also notice increased whine from the gearbox particularly in the intermediate gears.
- 2cams70
Before you start removing the gearbox make sure that the box has sufficient clearance from parts of the body and chassis. The reason I say this is that I had a similar noise a few years ago which l thought came from the gearbox and I actually purchased another gearbox in readiness to investigate. However before I built up the necessary enthusiasm to take the box out I accidentally realised that if I pushed up the bottom of the dashboard with my knee the noise disappeared! It turned out that the gearbox tower was coming in contact with the bottom of the dashboard. After filing a bit off the relavant area of the dash the noise stopped . I was astonished how much the noise had been amplified to sound like a serious gearbox problem.
Best of luck
Ed
Best of luck
Ed
EPA - Second Gear
