Metallic rattle
I had exactly that, but at high revs. Was on the point of ordering timing chain and gears having tried adjustment but put it on the lift for one last look. The back alternator bolt was loose. two minutes later the rattle had gone. If only I'd noticed that the movement had caused the feed wire to break...???...
I suppose the moral is to look for simple solutions first and spanner check!
- clivetonge
denicholls2 wrote:a mixture that goes rich for a moment when the throttle plates snap shut. On Italian cars and motorcycles, this often causes either burbling or backfiring as some of the unburned mixture sneaks out into the header pipe and ignites there
so THAT's whats causing my +2 burble on the overrun i thought it was an air leak at the junction of my headers and middle section ....
RichC - Fourth Gear
Thanks for all of the suggestions
Haven?t had the chance to inspect the car but did go for a quick drive. The rattle is still there but happened under different circumstances....strange
I did get it to happen when stationary and in neutral although not every time I reved the engine - only occasionally
It happened in every gear under acceleration this time and only very briefly.
Where it happened in the rev range varied a bit.
It also happened a couple of times while the car was idling stationary warming up
I thought I might tighten the timing chain a little- is it ok to do this without taking the cam cover off?
I presume you screw the thread in (clockwise to tighten).
Thanks again
Andy
Thanks again
Andy
- andyhay
Andy,
Since it has occurred in neutral i would buy a cam cover gasket and lift the cam cover. Not a fan of blind adjustment unless you are doing it regular and aware of noise and feel.
Then check the chain tension in various positions to ascertain the tension. I would also look down at the tension sprocket with a torch and see if there is any unusual side wear on the teeth. Also look at the way the sprocket sits with the chain alignment. I had this going on and it turned out to be a slightly twisted quadrant that was causing the sprocket to run out of alignment with the chain. This was self inflicted. I had twisted the quadrant slightly when it was out when i fitted a new sorocket. The large socket that tightens the axle/bolt can apply a lot of force. I found this early and the wear marks at opposite sides of the sprocket gave witness. Also some very light metalic debris on sprocket.
If not this you can check the chain tension properly. If it is I wrote a script for checking on both planes. Mine only appeared as the engine warmed and the oil got thinner. Also only at certain revs.
Cheers Mike
Cheers Mike
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Starting to sound like an irregular metallic rattle from somewhere forward of the driving seat that I had back in the summer while driving through France. Started as just now and again, then at certain revs and finally quite a lot of the time under about 3k rpm.
I tracked it down in the hotel car park to the bottom right dash fixing screw had come undone and the nut was rattling against the metal bracket.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Just another point. I listened with a long screw driver around the engine and picked up the rattle at the front timing sprocket area whilst playing with the throttle.
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked wrote:Just another point. I listed with a long screw driver around the engine and picked up the rattle at the front timing sprocket area whilst playing with the throttle.
I was just about to suggest the screwdriver listening method. Another item to check is the dynamo/alternator bolts top and bottom and the water pump pulley bolts.
Dan
I took the car out again with a mate to help narrow down the source of the noise with some success.
Used the screw driver method to listen for noise at timing chain - definitely not there. It?s lower and back further in the car.
We found a way to make the noise happen consistently while stationary. Depress clutch - put in gear briefly then lift clutch. The noise happens about 2 seconds after lifting the clutch. Happens using any gear and almost every time.
Sounds like some thing metal spinning down and becoming wobbly and brushing against another metal surface.
Any ideas?
Could it be this :
lotus-gearbox-f37/clutch-noise-t22527.html
Andy
Any ideas?
Could it be this :
Andy
- andyhay
That's your clutch release bearing making the noise. The clutch lever should have about 3mm (1/8") free play from the slave cylinder rod. There should be a retaining spring between the lever arm and the slave body to keep the bearing from contacting the clutch fingers when the clutch pedal is not depressed. If it's missing find a replacement from one of the usual suppliers.
The bearing is worn and has some looseness. Mine has been that way for years.
Hi all
I tried to adjust the spacing at the clutch release arm this morning - I can?t access without removing the exhaust - impossible to turn the nuts.
I think removing the exhaust is too big a job for me without a hoist. I?ll book it in with a mechanic.
Thanks.
Andy
Thanks.
Andy
- andyhay
Andy,
Understood about access to the nuts around the exhaust. You should be fine temporarily.
Hi Andy,
Does it sound like this https://1drv.ms/u/s!AsOq-jbOtbQkguJkUVjpVStsIMMmhA as that's my plus 2 on the over run?
Before you get your hopes up I haven't solved it yet, but there are lots of suggestions to my post in the Gearbox/Driveline section under "What's this noise" which may be useful.
I also posted a video of it on instagram @62rhj (the pictures of the gear lever) and the suggestion from there that I think is most likely is the detent springs on the selector rails. Later editions of the workshop manual say these three little springs need shims placed on them to prevent vibration and noise - which has solved the issue for others.
I haven't yet taken my box out so not tried this solution yet. My noise seems to come from just in front of the gear lever behind the dash - which is where these springs are.
Whatever the eventual cause is - we're not alone as it seems there are a lot of plus 2 owners that suffer the same noise!
Good luck and let us know if you find the answer!
Elan + 2 50/1179 Owned since 1983
Instagram @62RHJ
Instagram @62RHJ
Richard J - First Gear
