Lotus Elan
1969 ELAN+2 SE, powered by TR6 unit
PostPost by: john.p.clegg » Wed Jan 16, 2019 3:03 pm
Will the speedo drive cable have a tight turn exiting the chassis or be trapped under the body?
John :wink:
PostPost by: gusvlachos » Thu Jan 17, 2019 6:50 am
Mazzini wrote:Looking good, but just a thought, do you think the Rotoflex couplings are up to the additional weight and power?
Original differential unit & shafts train are temporary to the car, they are weak for this engine.
As I mention before, it will be replaced by TR 6 unit, which is stronger and heavier, but contributes to better front/rear weight ratio.
Power/weight ratio are not in the main task, as it is to built a reliable car for regular use, not for racing. :D
Gus Vlachos
gusvlachos
First Gear
First Gear
PostPost by: gusvlachos » Thu Jan 17, 2019 6:51 am
john.p.clegg wrote:Will the speedo drive cable have a tight turn exiting the chassis or be trapped under the body?
John :wink:
Exactly :)
Gus Vlachos
gusvlachos
First Gear
First Gear
PostPost by: gusvlachos » Thu Jan 17, 2019 6:53 am
+1
Gus Vlachos
gusvlachos
First Gear
First Gear
PostPost by: gusvlachos » Thu Jan 17, 2019 6:57 am
Certified Lotus wrote:Very nice work! Impressive.
Gus Vlachos
gusvlachos
First Gear
First Gear
PostPost by: Peter +2 » Thu Jan 17, 2019 8:39 am
Projects so well executed like this one are a pleasure to see.
Please keep us updated.
Peter
1968 +2 BRM
Peter +2
PostPost by: gusvlachos » Thu Jan 17, 2019 11:47 am
Peter +2 wrote:Projects so well executed like this one are a pleasure to see.
Peter
Ok .
Gus Vlachos
gusvlachos
First Gear
First Gear
PostPost by: Elan Peter » Thu Jan 17, 2019 6:14 pm
Beautiful car! The attention to detail is fantastic. I bet it will sound wonderful!!!!
Keep up the good work! :D
Best regards, P
Peter James Evans
1965 Elan S2 (Early 26R replica)
1972 Elan Plus 2 S130 (Next project, awaiting full restoration)
196? Elan S2 (To be restored after the plus 2, completely standard)
1980 Lombardini/Westwood
Elan Peter
PostPost by: gusvlachos » Fri Mar 22, 2019 1:40 pm
Hi to everyone,
After a major health problem with a happy end :D, I 'm back to continue the project.
Here are some exhaust system details, and a start up test video, prior to final bolt on chassis & body together.
img_20190224_140403.jpg and
img_20190304_143237.jpg and
img_20190224_140631.jpg and
img_20190224_140449.jpg and
img_20190224_140325.jpg and
img_20190224_140253.jpg and
img_20190222_124640.jpg and
Gus Vlachos
gusvlachos
First Gear
First Gear
PostPost by: gusvlachos » Fri Mar 22, 2019 1:49 pm
Sorry video is too large for uploading in this site?!
Here it is:
https://youtu.be/HZtR-Wf3KqY
https://youtu.be/MfY3dJQ_lSk
Gus Vlachos
gusvlachos
First Gear
First Gear
PostPost by: SENC » Fri Mar 22, 2019 2:52 pm
What a great looking build!
Post your video to YouTube and share the link here.
Henry
69 Elan S4
65 Seven S2
PostPost by: JonB » Fri Mar 22, 2019 5:32 pm
That's an excellent solution to mounting the exhaust. Look at the clearance...
PostPost by: gino1 » Sat May 18, 2019 11:17 am
That?s a really nice build and a very tidy garage you?ve got there.
Well done
Gino
1965 Elan S2 Roadster
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: vincereynard » Mon May 20, 2019 10:46 am
Beautiful job Gus. Congratulations!
Out of interest did you consider tying the chassis to the sill plate with tube / boxes front and rear to stiffen the chassis?
PostPost by: gusvlachos » Tue May 21, 2019 5:57 am
vincereynard wrote:Beautiful job Gus. Congratulations!
Good morning Vincereynard,
and thanks to you, SENC, GINO, JonB, Elan Peter, Peter +2, Certified Lotus,.. for your replies and encourage words !
Almost all known mods for stiffness to the std Chassis previous posted to" Lotus Elan.Net " , have been done and much more. The "box" technic applied everywhere were possible.
Original chassis have been rewelded and reinforced with 2mm & 3mm plates inside-out, especially in front & rear towers,as well as crossmembers, TUNNEL and all mounts & weak points prone to crack.
In conjuction with the "limited roll cage " !, the reinforced GRP body and the adds of tower/strut bars front & rear, the roll stiffness of this project 'll be exceptional for road use. :roll:
Gus Vlachos
gusvlachos
First Gear
First Gear
PreviousNext
Users browsing this forum: elaninfuture and 11 guests
