outer window trim needed
Sat Nov 12, 2016 9:33 pm
by vararacer02
Help I need the outer window trim on the door both sides just missed one on ebay any help would be appreciated
thanks scott
vararacer02@aol .com west coast USA
Re: outer window trim needed
Mon Nov 14, 2016 9:22 am
by nigelrbfurness
Do you mean the felt strips that run along the top of the door and trim the slot? If so, they are readily available from Matty or Steve Roberts, both will post to the US.
Mon Nov 14, 2016 4:45 pm
by vararacer02
Thanks for the reply what I need is the chrome strips on the outside at the bottom of the window opening
Thanks for the help
Mon Nov 14, 2016 6:38 pm
by mr.vman
I have the bottom window trims for the +2 door, both sides, not new, removed from my parts car. These are the trims that go bellow the window, are held in with clips that also hold in the window frame assembly. Not the long trims that fit under the door on the rocker panel/sill. There was another list member in Southern California looking for the trims (last week?), as I understand, found them at S&J Lotus in the UK? Hope this helps.
Steve V.
Wed Nov 16, 2016 1:17 am
by wwpete
I have a set as well. nice shape. no clips.
