Ford engine in a +2? Please help!
PostPost by: karlos » Thu Nov 10, 2016 8:45 pm
I fond this car in a barn with a Ford Engine on it.
is it possible? I thought all +2 had lotos engine.
Car Plate: Typr50
Unit n.? 7001.030029M
Engine n.? F/21905
Could some one check, please?
Tks,
karlos
New-tral
PostPost by: RogerFrench » Fri Nov 11, 2016 3:49 pm
Easy to put a Ford engine in. Maybe the Lotus engine broke.
RogerFrench
PostPost by: theelanman » Fri Nov 11, 2016 4:08 pm
a Zetec or Duratec or crossflow will fit.......
aswell as the original twincam......
:mrgreen:
the twincam has a ford block
theelanman
PostPost by: Sea Ranch » Fri Nov 11, 2016 6:19 pm
The Lotus Twin Cam IS a Ford engine, with a Lotus alloy dual overhead cam head on it. Plus Ford bell housing, gearbox, differential.
Is that what you're seeing?
Sea Ranch
PostPost by: nigelrbfurness » Sat Nov 12, 2016 9:24 am
It was not uncommon to find Elans with ordinary Ford engines back in the early 70s - I had several, usually with 1500GT Cortina engines - as at that time it was expensive to repair a twin-cam properly and lots got bodged. I remember buying an Anglia van (which was a death trap) someone had put a smoky TC in, swapping it out for a 1500 from an Elan S1 and selling both for far more than I paid for them. That would have been around 1973, I think. Heady days. Too old now for such shenanigans. Yawn, where's my teeth?
Nigel F.
nigelrbfurness
PostPost by: jono » Sat Nov 12, 2016 12:43 pm
....ah ah!
The Lotus twincam is actually a Lotus designed and built engine which happened to use a Ford bottom end mated to a Lotus twin cam head and bespoke front cover/water pump assembly :D
...just being provocative :wink:
PostPost by: elansprint71 » Sun Nov 13, 2016 10:12 pm
Yes, but.... can anyone help our new friend with the numbers he has supplied? I have no info on the +2.
PostPost by: TroonSprint » Sun Nov 13, 2016 10:30 pm
Could Karlos post a photo of the engine?
TroonSprint
