Plus 2 or Plus 2S
Sea Ranch wrote:My February 1970 Federal Plus 2S (all the S features) has 2 fog lamps, definitely original from the rust and similar amounts of pitting on both lenses.
Randy
Randy, are they switched separately? Only in all the wiring diagrams I have for the +2'S', including federal, they clearly show two switches, one labelled "Fog lamp switch" & the other labelled "Spot lamp switch" & the two respective bulbs labelled "Fog lamp" & "Spot lamp", Whereas for the 'S130', again both federal & home market, they show only one switch, labelled "Fog lamp switch" & both bulbs are labelled "Fog lamp". Despite this, my 'S130' had one fog & one spot light, which I thought incorrect, but was subsequently told by more than one lotus specialist, & two ex-factory workers, that that was how they left the factory, at least until they had run out of spot lights. One of the ex-workers said he had suggested that they fit them in pairs, so one car would have fog lights, & another would have spot lights, but they were told to continue fitting one of each, as had been the case for the earlier models. Whether that's right or wrong, I can't say, but I can see no reason for him to make the story up. I suspect it's another case of there's no definitive answer
- Orsom Weels
KevJ+2 wrote:This is the workshop manual for Grizzly and Gus
http://www.ebay.co.uk/itm/lotus-elan-3- ... Sw44BYHLbn
Plus3,never knew there was such an animal....till now.
Seems the fog/Spot thing is an old subject... I'll have to go check but i think my S has a switch for each side just under the right side of the dash and my 135/5 just has one switch and a reset for the Odometer.
lotuselan-plus2-f51/lucas-square-t24658.html
Grizzly - Coveted Fifth Gear
KevJ+2 wrote:theelanman wrote:Kev
I thought all +2's had the electric and the elan had the hydraulic.....???
must be one of the ones that got away.......
Maybe Gus will know
Mine has mechanical oil pressure gauge........because I stole one from a TC Europa.....
AFAIK they should all be electric, in fact I swapped the gauge positions because the mechanical is much deeper and would not clear the defroster vent
- gus
Orsom Weels wrote:Sea Ranch wrote:My February 1970 Federal Plus 2S (all the S features) has 2 fog lamps, definitely original from the rust and similar amounts of pitting on both lenses.
Randy
Thanks, Tim. My car (Feb 1970) has the two separate switches for the lights. You know, perhaps one of the lens was replaced after breakage and that's how I ended up with two fogs. But they have such a uniform "road sand" blasting that they must be very similar in age.
It would not surprize me to find that on the assembly line, if they ran out of spots that day, they installed dual fogs on occasion.
Randy
