Wiper Woes
• Page 3 of 4 • 1, 2, 3, 4
I too have a faulty wiper motor. When Fitted in the +2 found there is no second speed and not parking, low speed is good. Motor is two speed 14w with a 125 deg gear. Tested on bench and first speed ok but no second speed, any ideas? I will dismantle, might just be broken wire.
Replacements are available, but some do not include the gear and arm assembly.
Les
Les
- Elseezed
Les
No parking shows that the contacts in the connector block are not shorting out the "slow" 85 Ohm coil.
as for the other problem ,it could be anything...
Glad you've got to the bottom of it Les.
Anyone got any thoughts about the replacement bearings I mentioned a few posts back?
I've been googling but come up with nothing.
www.s-v-c.co.uk seems like a good bet for either a full motor replacement or just a gear wheel and shaft but I see little point in replacing the shaft if the existing bearing it contacts is damaged.....
- gavk
I think the bearing is a phosphor-bronze bush,if you measure the size then Fleabay/Amazon/Google it...
Les
P.S. I'll look in my box of bits and see if I have a brush assembly...
Les
Just had a look in Gavs link and this.... ?11:00 including VAT
http://www.s-v-c.co.uk/product/wiper-mo ... h-and-pad/
seems the best route rather than messing about ?
But I'll still look for the brush/holder if you want me to...
Les
Their brush holders/board look cheap and nasty,not as good as the Lucas kit...
Bought brush Assy and switch from G. E. Middleton, City Road, Manchester for ?21.
Switch fits by clipping onto wiper body. Not in my case, looks like I have to drill and file body to attach clip.
Middle tons sell a new motor for ?27.50 + vat
I asked about bearings, they said they can not get them nowadays.
Why me? Les.
Why me? Les.
- Elseezed
Les
I may have a good casting with the proper cut-outs if you want it ?
