Together at last
Very nice, still really liking that colour.
I'd expect the suspension to settle quite a bit so wouldn't worry about it for now. Being a bit higher should make it a little easier to work on.
- mbell
Looking good.
The ride height, especially at the front, will no doubt look too high even when the car is completed, mine certainly did. It settles down after a few runs.
Dougal.
Dougal.
- dougal9887
Looking good. The car always looks high when the body first goes on. Its surprising how much weight the interior of the car, carpets, glass, wiring etc etc contributes. Now is the the time to make sure the body sits right - check the dimensions match all round, especially side to side before you tap & bolt the body on.
This was the fit with mine straight after the lift onto the rolling chassis. It soon settled down, especially with adjustable springs.
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
JJDraper wrote:Looking good. The car always looks high when the body first goes on. Its surprising how much weight the interior of the car, carpets, glass, wiring etc etc contributes. Now is the the time to make sure the body sits right - check the dimensions match all round, especially side to side before you tap & bolt the body on.
Jeremy
Your Plus 2 looks lovely! Normally I think Elite's are beautiful in any colour, however...orange??? Ouch!
Mazzini - Coveted Fifth Gear
Mazzini wrote:Your Plus 2 looks lovely! Normally I think Elite's are beautiful in any colour, however...orange??? Ouch!
Sorry, not my Elite.. My +2 now has more, errr ..... Patina, that's the word, after 6 years! A word to Shaun - it is well worth it, but the time after getting the body back on seems to drag on forever - It will be worth it!
Jeremy
Very nice i'm a fan of Green +2's (some how suits the shape more than most other colours)
Regarding the suspension. I found with mine when its been over extended for a while the struts tend to stick, i had all sorts of problems pushing my koni's fully in to adjust them before final assembly.
Grizzly - Coveted Fifth Gear
Shaun, that really is the most gorgeous colour I've ever seen on a +2. Its taking every ounce of strength in my body not to be a filthy copycat.
I will try and stick with lagoon blue (which is also very nice).
What size of metallic flake did you go for? Is it finer than the older paints? It looks fairly modern.
- Own Little World
Thanks for the comments i was always concerned about painting a non lotus colour but after much head scratching I came upon this almond green ,it's ideal not having to much flake as I wanted to try to keep it in period of the late 60s and not to glitzy
- shaun
Users browsing this forum: Andrew G, lotusfan, rgh0 and 13 guests
