Considering '70 Plus 2 purchase
• Page 3 of 3 • 1, 2, 3
I brought the car home today!
The bad news is that I still haven't actually driven it due to a leaking clutch-line...but I'm nevertheless CHUFFED to have the Plus 2!
Foggy morning, waiting for the tow truck:
Home now:
Home now:
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
CBUEB1771 wrote:It still has the cross-over tubes for preheating the inlet mixture.
I meant to ask a while back, is it common for these to be removed, and what are the pros and cons of doing so?
2012 BMW R1200GS
2012 BMW R1200GS
Yes, it is usual to remove the crossover pipes.
As I understand it you lose nothing by doing so but gain better access to the engine and perhaps a couple of extra HP - who knows?!
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Thanks gents, that sounds like a good thing to add to the project-list. And a previous owner has already done the CVJ conversion, so any remaining comical effects should be entirely my own fault!
2012 BMW R1200GS
2012 BMW R1200GS
The Veg wrote:I meant to ask a while back, is it common for these to be removed, and what are the pros and cons of doing so?
Yes, it was common practice to remove the cross-over tubes, blank off the two ports on the top of the secondary throttle housing and remove the secondary throttles from that housing. Nothing is really lost by this. However a much better solution is to find a set of inlet manifolds used on engines with Stromberg carburetors in markets outside of the US. These manifolds have a balance tube connecting the siamesed inlets to cylinders 1/2 and 3/4. The balance tube promotes more uniform cylinder filling. Without the balance tube cylinders 2 and 3 fill slightly less than 1 and 4 due to the phasing of the inlet strokes. These versions of the inlet bodies with balance tube are clearly illustrated in the Service Parts List. I am not sure where you might find a set of these now. You might try Spyder in the UK, they tend to keep items removed when doing their Zetec engine conversions.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
theelanman wrote:2036
engine number I20375 4 speed box yellow built 3 July 1970
I did not know when I asked the question that I'd find this on the car:
So who's right?
2012 BMW R1200GS
2012 BMW R1200GS
