Lotus Elan
Newbie
PostPost by: Spaximus » Thu Jun 04, 2015 7:18 pm
Hi All,
My name is Jeff and over the years I have built many things, latterly I have built several Westfields. Having got older and wet too many times I sold my road car and now just have my track car, which can be used on the road if you like your spine crushed and fillings falling out.
I am seriously considering either buying an Elan +2, having seen a good example and there is also a convertible that looks fine. However I am being drawn towards building a Zetec engine Spyder chassied car.
So a few questions, does anyone know of a complete shell, ie everything bar the chassis.
What to look for when buying one, is there steel in the bodyshell anywhere to be warey of?
Any recommended reading?
Any recommended specialists for spares etc.
I work for a company who distributes car parts to motor factors across the Uk so many parts I can get but special Lotus only is a no no.
Thanks in advance
Jeff
Spaximus
New-tral
PostPost by: Europatc » Thu Jun 04, 2015 10:16 pm
Welcome Jeff
all the best
Stuart
Europatc
PostPost by: cal44 » Fri Jun 05, 2015 1:57 am
Buy a junker with a rotted frame. Hopefully all the parts are there. I would avoid simply buying a shell as you will darn near need everything that goes with it.
"Be Polite, Be Professional, But have a plan to kill everyone you meet"
General "Mad Dog" James Mattis United States Marines
cal44
PostPost by: Sea Ranch » Fri Jun 05, 2015 2:07 am
Welcome, Jeff.
Yup, agree with Mike.
Also, there is a section on this forum for modified cars, and many, many enthusiastic builder/owner/posters here.
To answer but one of your questions, the Plus 2 has mild steel folded triangle-section reinforcing members in the sill areas under the doors (we usually refer to them as sill members). They bolt to the lower fiberglass flange of the sill and also at three points inside, and serve as outer seatbelt anchors. And they rust like crazy.
But they're relatively simple and inexpensive to replace. Make sure you do that with the shell fully and properly seated on the chassis, with doors in place. Then you can remove the shell and do bodywork, etc. (which is the current state of my car, as seen in the avatar :shock: ).
Read the period magazine reviews and tests. The Plus 2 will be an excellent experience for you, compared to driving a track car on the road: awesome handling and superior ride. :mrgreen:
Good luck finding the right donor, etc. . . . regards,
Randy
Sea Ranch
PostPost by: gherlt » Fri Jun 05, 2015 8:25 am
Hello and welcome,
If you want to build such a car from ground up you will end up spending more money than buying one.
It might be better done, yes.
But because "non-original" cars tend to be cheaper, a +2 zetec conversion is quite "common", I rather would wait for an opportunity to buy one.
Reards
Guillermo
1964 S1 (engine ready, awainting body paint)
1967 S3 DHC (now adjusted by Brian Buckland, totally calm idle)
1969 S4 FHC (final interior stuff)
gherlt
Users browsing this forum: nmauduit, prezoom and 10 guests
