Plus 2 rebuild
ID plate
Getting the hang of this IT stuff now
Shaun
your brake pipe routing is non-standard...but nice,,
Salut shaun
Beautiful work !
I have complete braided brake lines, too - direct from the unions to the calipers. However I followed the original routing which does leave them less exposed:
Similar for the front - held in place by rubber-lined P-clips.
Vernon
Beautiful work !
Vernon
vernon.taylor - Fourth Gear
Sea Ranch wrote:john.p.clegg wrote:your brake pipe routing is non-standard...but nice
. . . but subject to damage from road objects, as it's on the leading edge of the A frames . . .
Just a thought . . .
and looking at it again it could chafe on the ball joints/arms..
Most forest rally cars use braided brake lines that in one event will be exposed to far more flying rocks, stones etc than a road car will in several lifetimes. Brake failure due to brake line damage is quite rare. The reason braided lines are used is that they are extremely resistant to wear & damage from flying objects, not because they look good.
- Mick6186
In my recent outing competing at the Sandown Historic races in my Elan there was a very load clang from the rear during the race. Nothing seemed to happen to the handling so I continued on. After the race I checked the rear suspension and found a very large indentation on the leading side of the A frame front tube where a stone / rock had been thrown up from the front wheels. The indentation was the like the tube had been hit very hard with a ball peen hammer. Even a braided brake line would have been crushed and potentially cut by the impact.
I would route the brake lines via the original locations or at least put on the back side of the suspension
Users browsing this forum: smiths everest and 16 guests
