Rad Cap
Sorry to post using two postings but my memory is not what it used to be.
I am also looking for a radiator cap part number for a standard 1969 Elan +2 radiator. It must be compatible with coolant recovery. I understand that will require two rubber seals on the cap.
thanks
Bob
thanks
Bob
- rdssdi
If you are in the UK, Sue Miller sells the correct one. You just need to specify the pressure release setting that you want.
Eric in Burnley
1967 S3SE DHC (off the road again)
Eric in Burnley
- ericbushby
Located in U.S..
Cap that I have says "T5 G700" 10lbs.
Any idea what it is from?
Bob
Bob
- rdssdi
