checking body/engine/gearbox numbers
Might not be worth the effort if you are just considering the car rather than own it, but the Lotus Archivist can sometimes provide some info. From the VIN (i.e. number formatted 50/xxxx on the data plate) he was able to tell me engine number & confirm car was sold in Canada and the date, but not original colour of the car. The available information on the early cars varies quite a bit, and some records were lost.
Andy Graham = [email protected]
Some folks here have copies of some chassis & engine number data. Perhaps post the numbers you find on the car under a general question in the discussion forum and someone may be able to confirm some data for you.
HTH
HTH
Stu
1969 Plus 2 Federal LHD
Interesting question ! given that most Elans are over 40 years old ,and have had several owners ,some not so caring !! ,unless you are very lucky ,having matching no's is not likely ,exchange engines and gearbox replacement over time is the likely cause !! and what does matching no's prove ! I have had 3 Elans and a +2 and only the first had it's original engine but this did not detract from the enjoyment of the car.
- pete d
I have never noticed any mention of gearbox assignment on these cars so the only thing needed there, if it matters, is the correct era gearbox. Correct engine number can sometimes be understood by the chassis plate and the LP number on the block but even then the cylinder head may be different, Again having the correct era head will suffice if one is trying to stick to an original restoration.My S2 has matching body/chassis/engine numbers and I am not sure if that would make any difference in the value of the car. It's simply a correct S2 Elan with no overt modifications (internal engine upgrades like cams(Sprint), compression, fully ported big valve head headers and a very careful blueprinted rebuild), upgraded starter etc..Quick, reliable and good looking and a very enjoyable car to drive as often as possible !.
- Jeff@Jae
My 67 has matching VIN, block and chassis numbers. I don't know about the gearbox, I haven't needed to look at it yet.
I did get confirmation from Andy Graham that they are as built. He could not confirm the original color, said that I would have to try to track down the original dealer for that.
He was able to tell me the original dealer name and that they were in Los Angeles. My Elan seems to have stayed in Southern California all it's life.
I'd like to find out how many previous owners it has had.
- PBrown60
Users browsing this forum: MAC2, Mallydeganwy, smiths everest and 25 guests
