New plugs - amazing
Yes it's interesting what the service intervals are for plug replacement on modern cars like audis, in the order of 60,000kms.....which is just as well given their price!
But many's the time I've been struggling to get an old banger (cortina, ?lan etc) going after a lay up, and when all else fails, whipping out the plugs and replacing them has had instant results, ie instant start, full power pickup and smooth idle.
Wonder what's changed over the years to make plugs last so long in modern cars.....
- robertverhey
Does nobody clean plugs anymore??
I would say, they have now "precision" ignition and therefore a much cleaner combustion.
1964 S1 (at paint shop)
1967 S3 DHC
1969 S4 FHC (at BB's home)
1967 S3 DHC
- gherlt
Agreed, my S3 suffers from similar issues after the winter break, this year I have fitted a set of NGK BP6ES spark plugs and now I find that old engine starts better and runs smoother through the rev. range, It appears that these plugs seem to suit todays unleaded fuel better than the BP7ES plugs ......................... ???
Paul
- Paul Chapman
Paul Chapman wrote:Agreed, my S3 suffers from similar issues after the winter break, this year I have fitted a set of NGK BP6ES spark plugs and now I find that old engine starts better and runs smoother through the rev. range, It appears that these plugs seem to suit todays unleaded fuel better than the BP7ES plugs ......................... ???
The 6 runs hotter than the 7 and therefore won't foul as readily.
RogerFrench - Fourth Gear
The Lotus recommended NGK BP7ES or equivalent was always to cold for normal road use even back in the days of leaded fuel in my experience. I think Lotus based their recommendation on the hard use they expected from the buyers back then !!!!!
My experiences are:
Normal engine / normal road use - BP6ES
Normal engine / sustained high speed use - BP7ES
Race Engine / hill climb use - BP7ES or BP6ES depending on how much warm up chance you get
Race Engine / race use - BP8ES assumes a warm up lap to get the plugs up to temperature under load
Current emissions regulations require spark plugs to last typically 100,000 kms. This is possible with the fancy metals used these days to stop electrode erosion and with fuel injection and electronic ignition and low oil loss designs in modern engines all preventing fouling of the electrodes which is the normal reason plugs in a twin cam go off.
My experiences are:
Hm. My car will only run on 2 cylinders at the moment, but was fine the other day before I washed it. I checked out the plugs from the same lead and found that a couple of them had what I would call a healthy spark and two nothing to the electrode. All the leads seem to be working fine. It must be a combination of very old plugs - they've sat in the engine for some years now - and damp in the distributor cap or on connections to the coil.
Regards.
Sean.
Regards.
Sean.
- alaric
I agree with Everyone about NGK6's for every day running.
Interestingly, last week I was "fettling" to try and get in top of some uneven running.
I used a Gunson colourtune & the ste synchro device to balance the carbs up. As I only have one colourtune this meant I was having to swap plugs in and out with the engine reasonably warm. Having got the carbs much closer, I didn't have time for a final test drive & parked the car up.
Today, I took the car out again & it protested a bit here & there. Lots of popping and banging on the overrun & temperatures went up at the merest hint of a traffic queue. Went to check the plugs once I got back & they were all loose 1/2 a turn !!!
I usually torque them up but recall I didn't when tuning last week as the engine was hot.
When i did look at them- the Plugs were grey/white by the way !! Difficult to know if the lean running is because the were loose or whether it was down to my tuning attempts.
So moral is...check,check & check again !
'72 Sprint
'72 Sprint
- richardcox_lotus
alaric wrote:Hm. My car will only run on 2 cylinders at the moment, but was fine the other day before I washed it. I checked out the plugs from the same lead and found that a couple of them had what I would call a healthy spark and two nothing to the electrode. All the leads seem to be working fine. It must be a combination of very old plugs - they've sat in the engine for some years now - and damp in the distributor cap or on connections to the coil.
Regards.
Sean.
Also worth checking the grub screws which clamp the HT leads into the distributor cap.....they go rusty and can be the cause of a weak spark.
S4 DHC
S4 DHC
- oldelanman
john.p.clegg wrote:Does nobody clean plugs anymore??
I wonder about this too - DOES anyone?
I find that a new plug is always better than one that ive cleaned (and at $4 a pop wonder whether messing about is worthwhile).
I am interested to know what techniques others use to clean plugs - I brush them, file the electrodes and set the gap.
Old books show a thing like a mini-sandblaster but Ive never heard anyone use one.
I do hate the waste of replacing a newish plug- and now have a collection of the undead ones.
Russ
rfurzer - First Gear
rfurzer wrote:john.p.clegg wrote:Does nobody clean plugs anymore??
Russ
I clean mine with a stainless wire brush and bend the side electrode to set the gap.....
I'm not rich but have 4 colourtunes to overcome the problem,,,,but this only affects the mixture at tickover...
