lotus elan +2 restoration
• Page 1 of 5 • 1, 2, 3, 4, 5
Hi guys, I'm the Italian owner of a Lotus Elan +2 1970 in restoration, and I have problems to recover the differential housing, would know someone help me out, thanks hello
- nicolacoltro
Hello, no differential was already removed, the machine is restored with a complete frame off, what I can not find on the market is this piece attached, thank you and hello to all
- nicolacoltro
Hi and welcome
Try these guys:
http://www.englishdiff.co.uk/
or
http://www.burtonpower.com/parts-by-fit ... 5&limit=40
Jason
Try these guys:
or
Jason
Jason1 - Coveted Fifth Gear
That part is common to many "Ford English differentials", you could try ebay or companies specialising in rebuilding Ford diffs along. I know Mick Miller Lotus have a guy who builds diffs for them, maybe he has a spare or better still send your diff to them and get it properly built and set up.
Good Luck
Good Luck
c42 - Third Gear
This ebay listing may be of interest to you....I have no connection with seller:
http://www.ebay.co.uk/itm/ford-escort-m ... 416ad2a1de
another question guys, where can I find the tachometer, thanks
- nicolacoltro
Hello guys, I contacted a dealer ford axles and asks me if mine is the same as the Ford Escort Mk1 or Mk2, I do not understand anything ...
- nicolacoltro
Nico
Where are you ,I may be able to help...
Hello guys I wanted to ask a question, I'm on my ELAN +2 retaurando a kind of reinforcement is mounted between the frame and the frame left and right between the radiator and engine (made ??by two attachment plates to the frame connected by three rods with ball ), I do not think it is an original piece not because I've never seen on any other ELAN +2, those who know something?
- nicolacoltro
Never seen anything like that! Could be a way of preventing flex between the two suspension towers? You sometimes see something like this on metal-bodied rally cars to prevent the body shell flexing.
Difficult to see. Not sure why it would need ball joints (rose joints). Looks like its been put together from steering rod end joints. Could have been a mod for rough roads/motorsport. I can also see a riveted metal plate on the bodywork on the left hand mounting point..
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
