Ghost exorcised
My +2 had developed the most embarrassing problem - phantom beeps with the airhorns. Often just a little bip, but sometimes a loud hoot. This happened at seemingly random moments, but often when going round roundabouts or in multi storey car parks. Even taking the pencil out of the steering wheel didn't stop it. After separating the wheel from the steering column, all became clear. The wheel boss was too close to the brass horn track; but microscopically so. Bit of 'G' or serious wheel twiddling cause a slight short. Undo column clamp and pull column up half an inch. Problem solved, and no more looks of 'ar***ole' from the cars in front
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
Robbie
JJDraper wrote:My +2 had developed the most embarrassing problem - phantom beeps with the airhorns. Often just a little bip, but sometimes a loud hoot. This happened at seemingly random moments, but often when going round roundabouts or in multi storey car parks. Even taking the pencil out of the steering wheel didn't stop it. After separating the wheel from the steering column, all became clear. The wheel boss was too close to the brass horn track; but microscopically so. Bit of 'G' or serious wheel twiddling cause a slight short. Undo column clamp and pull column up half an inch. Problem solved, and no more looks of 'ar***ole' from the cars in front
Jeremy
Check your turrets. It sound like Tourettes Syndrome for cars
Henry
1967 S3 FHC
A joke a day helps you work, rest, and play.
1967 S3 FHC
- Henry VIIII
