Lucas Square 8
Jono
When I tried to buy a set of these a few years ago the answer was that they came complete with the rear , light unit and the cover. I managed to get some on ebay as they are very very common. Prices do vary especially if the listing mentions Mustang or Rolls Royce!
http://www.ebay.co.uk/itm/ORIGINAL-MK1- ... 58925d631f
http://www.ebay.co.uk/sch/i.html?_nkw=l ... m270.l1313
All the best
Terry
All the best
Terry
- terryp
Thanks Terry - I have been watching those
Do you know if the lights on the +2 were one spot and one fog as they often appear paired in this way on Ebay?
What are these lights actually for on a plus 2? I have never actually understood their practical or intended purpose (other than as a typical bit of bling by Chunky )
Jon
Jon
- jono
Jono
The original ones on my old car were "driving lights" which were clear (a bit corroded), I fitted fog lights which were obscure type glass. I reckon the fog lights are possibly more useful.
(Although to be honest I never drove the car in the fog!)
I think you are right with the bling ......matches the silver top
Good Luck with the auctions
Terry
Terry
- terryp
I nave competed in 12 car rallies in my +2 which is fitted with these fog/driving lights. The rally is basically a navigation rally on quite country roads held at night duiring the winter. Hence always in the dark. I connected my lightd to come one when I switched to high beam. The lights were aimed to illuminate the hedges so they were pointing slighty outward and higer than normal. I found them invaluable for driving fast down very dark lanes. I added an additionnal switch which prevented them coming on on high beam for "normal driving"
I was also able to by replacement lenses at an auto jumble.
Andy
Andy
andyhodg - Third Gear
I'm pretty sure that the lights were one spot and one fog on the +2S and then both fogs for the +2S130
Robbie
Robbie
Robbie693 wrote:I'm pretty sure that the lights were one spot and one fog on the +2S and then both fogs for the +2S130
Robbie
Convention in the 1970's seems to be fog for the kerb side (LH) and spot on the driver's side (RH). I recall my Dad having fog lights fitted to his P6 Rover in 1971 (and again in 1974) and that was the arrangement. Having them individually switched seems to have been an Elan "unique" option.
- johns
johns wrote:Robbie693 wrote:I'm pretty sure that the lights were one spot and one fog on the +2S and then both fogs for the +2S130
Robbie
My 1969 'S' had one fog & one spot individually switched. My 1972 'S130' also has one of each, but they are switched together, ie one switch, so maybe I should have a pair of fogs & Robbie's comment is correct ? Makes sense to me.
Regards, Tim
- Orsom Weels
I'm pretty sure mine has the same combination ('73 +2 S130/5) i.e. driving and fog lights...
Craig Elliott - Third Gear
Surely if one is a spot & one a fog lamp, they would have to be switched separately? A spot running in fog would create a shed load of dazzle.. I suppose you could wire up the spot to full beam and the fog on dip, to operate only if the 'fog' switch is on.
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
Hi Everyone
My '73 S130/5 has a pair of fog lamps which are the original fitment
The original Square 8 lamps fitted to the Plus 2 had chrome plated steel bodies and while they're readily available new and secondhand they are very expensive. If however its only the glass that's required then try looking out for a pair of s/h lamps with the black plastic bodies. These are quite common and are a fraction of the cost of steel one, and of course, the glass is interchangeable.
Andy
Andy
- andyelan
