Classic car magazine
Not sure if I have missed another thread but there's an article on the +2in the latest issue. No great revelations but it's good to see the car being reviewed so positively.
- mikealdren
Could you let us know which issue? May, June or July? The Classic Cars magazine website doesn't mention the article in their rundown of the contents . . .
http://www.classiccarsmagazine.co.uk/
Perhaps I've got the wrong magazine?
Thanks!!
Thanks!!
Sea Ranch,
yes you've got the right magazine and web page and yes, it's the June issue.
- mikealdren
In case anyone missed it, I've uploaded it as a PDF. Hopefully there's nothing wrong in doing this, but if there is I'm sure someone will point it out.
Happy reading...
Ian
Happy reading...
Ian
- Attachments
- cc_elan+2_guide_june2011.pdf
- (766.75 KiB) Downloaded 629 times
Iyarno - Second Gear
...Nice but,what are the high compression pistons?
In that article (Thanks Ian for the pdf!) it says that the chrome front windscreen surround is non repairable (That we do know) and spyder can supply a rubber seal with a chrome insert.
I thought, and I am prepared to be corrected, that the later Plus 2's, had a different windscreen aperture, and hence the front screen was bonded in, as opposed to the earlier rubber seal, so what are Spyder supplying?
Reason for my interest is my screen is cracked but it does not leak. Last time the window muppets tried replacing the screen, they busted four before they got it right and it did not leak, so I am loathed to go through the process again, unless I can go for the rubber seal.
Any thoughts?
Jeff 72+2
Any thoughts?
Jeff 72+2
jeff jackson - Fourth Gear
Shop manual clearly states that the aperature is different, (from January, 1970 on, I believe) and if I'm not mistaken, this means the opening is smaller on the later glue-in models. In any case, the manual also clearly states that the two openings are not interchangeable with the two installation methods.
FWIW.
Jeff: 4 windscreens broken??!?!?! Ouch. How did they find that many to put in???
Randy
FWIW.
Randy
Users browsing this forum: Blazer_one, Marcus+2, TonyA and 10 guests
