What are these?
Hi Graham,
The small clips in pic one look like the wire clips that hold the support rods for the head lining. One end fits in the rod, the other, if remember correctly, is screwed into the body above the door.
The second bracket looks familar, my intial feeling is that it is a support for the steering column and is fitted in the drivers footwell. Not 100% though.
tcsoar - Third Gear
...and I second Chris' suggestion that the pieces of wire are used to hold the headlining support rods in place.
Craig
Craig
Craig Elliott - Third Gear
Sadly enough, I just happen to have a pic that shows my steering wheel fitted with the column bracket visible in the background... the joy of restoration. I used large spreading washers on the engine bay side rather than the two metal sections shown in your pic. Look for the holes in the bulkhead.
- alaric
