Parts Identification
Jono,
I think some are the following
11 and 12 are parts of the bonnet release cable assy.
7, rad brackets
4, lower dash bracket
16, bonnet hinge/support frame
5, bonnet release captive nut plates
6, looks like might be one of the interior light boxes
9, may be a handbrake support bracket
Dont recognise much else.
Simon
7, rad brackets
Simon
SimonH - Third Gear
number 10 looks like something I got off either then en of the steering rack or the end of the handbrake.....
Ive still got it somewhere....
Hi Jono,
maybe n?6 is surround for gearlever to hold gaiter in place
n?10 clamp to hold end of the outer handbrake cable in place under the dash
is n?2 a support stay for the electic cooling fan to rad brackets
It seems you have a big 3D Lotus Jigsaw puzzle to pass away a few hours
good luck Alan.b
good luck Alan.b
Alan.B
- alan
Cheers chaps,
I think that just about settles it for most items
Item 2 are however fairly chunky solid machined items - thye look a bit too heavy for a fan brace
Alan - No13, damn!! I built up the rear hub assemblies with new bearings and missed these out - will it matter?
Jono
Jono
- jono
No 1 appears to have been made up from an airbox, but to what end... no idea! Remnants of a weber linkage? - difficult to tell from picture. Modified for a square air filter - but no idea what the tube thingy is!
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
Given that most of the stuff you've got there is from the engine compartment/bonnet area, perhaps number 6 could be some sort of plinth/surround for the engine bay lamp - although it's hard to judge the scale of it compared to the other stuff... C
Craig Elliott - Third Gear
number 6 is the interior light surround....
the bit thats pop riveted to the fibreglass......
the head lining then goes over it then the light is fitted onto it....
Ive got a matching pair in the garage somewhere now its dropped into place
No. 10 looks like a clamp that fits at the rear of the parking brake mechanism.
8 and 9 look like the handbrake attachment brackets
16 fits inside bonnet flat arms are pop riveted to bonnet sides.
15 looks like boot floor support brackets. Look to see if one has little clips riveted on to capture the protrusion on floor bottom
12 look like the guides for the bonnet release cable. Fit on either side of firewall.
11 may be bonnet release cable ends. Look similar to early +2 not sure.
Bob
Bob
- rdssdi
