Zetec reliability?
Rich,
I have sent you a PM so we don't go off subject here....
Kindest regards
Alan Thomas
Alan Thomas
Okay I admit it, I have had a problem today
Mrs T and I are house-hunting: or to be more accurate Mrs T is house-hunting and I am Double-Garage-With-Workshop-That-Just-Happens-To-Have-A-House-Off-The-Driveway-Hunting.
Anyway we took the +2 as it was a nice afternoon, parked outside the house we are looking at, all without problem. Mrs T was disappointed with the house and especially the garden, so it doesn't matter a fig that I actually liked the 3 car garage with inspection pit and 250 square foot of workshop space with mezzanine above.
Got back in the car feeling a bit down and started her up only to be greeted by the starter motor pinion sticking causing a luvvly grinding thrashing noise, gave the starter a good wack with my old spinner hammer and tried again but no luck same thing, had to get towed by the AA back to my single car garage with no inspection pit and a measly 36 square foot cupboard laughingly called a workshop thats full of Mrs T's garden stuff.
I have had a look at the starter and it appears to be a pig to change, there are 3 Allen key headed bolts, one of which is at the top of the starter and virtually impossible to reach without extensions and wobble bar fittings, also I don't have Allen Key sockets, so it looks like ?20 for the sockets, ?60 for the starter and a long afternoon cursing and swearing........ I seem to remember my lovely leaky wheezy noisy old twincam having just 2no 9/16 bolts to undo for the starter, which would take about 10 minutes including driving up the ramps..... thats modern parts for you.
Kindest regards
Alan Thomas
Alan Thomas
....and let's hope that you don't need to change the ring gear?...
Alan,
To half quote you " Original is best"
- elanman999
john.p.clegg wrote:Alan
Hi John,
it's a pre-engaged starter so the ring gear shouldn't be an issue, most likely the internals of the starter are looking pretty shabby. I'm fitting the new one today i will give an update tomorrow.
Kindest regards
Alan Thomas
Alan Thomas
elanman999 wrote:Alan,
Hello John,
well it is an 'Original Zetec Elan +2', so I suppose it now needs modifying with a proper Ford Motorcraft product and not the generic item thats been fitted from new. The 10 minute thing with the LTC starter is mostly due to them having the bolts work loose, which sort of gives a head start on removing them
This is the first bit of unplanned maintenance that I have had to do, I'm not really looking forward to skinning my knuckles, although I often find the swearing and cursing to be quite therapeutic
Kindest regards
Alan Thomas
Alan Thomas
Okay, it took 15 minutes to remove the starter motor including driving the car onto the ramps etc, thats 5 minutes longer than a LTC +2.
There was no damage to the ring gear nor was any expected with a pre-engaged stater motor that hadn't worked it's bolts loose. A very reasonable ?65 for the starter motor from a Scorpio 2.3 of 1998 vintage, refitting was a very quick 8 minutes.
Boy! these Zetec Elan +2 cars are really unreliable and troublesome. I noticed that my Spyder chassis actually has a bit of surface rust on it, no doubt caused by the lack of lubrication from an engine that doesn't leak oil?
Comments gratefully accepted and expected
Kindest regards
Alan Thomas
Alan Thomas
