Sagging bottom
I'm in Discovery mode currently with my new acquisition 50 /734 and uncovered a 4" crack in GRP below battery running fore and aft alongside the chassis mounting plate. From underneath the bootfloor is seen to sag aft of the mounting plate and you can pick up the rear of the car quite a bit. Has anyone witnessed this before & if so ,what is the common remedy?
My thoughts run to fabricating a larger mounting plate before I tackle the rather major GRP repair... is that necessary & if so how big?? or is it just that at some time in the past some fat b****** has sat on the OSR wing?
I think the resultant flexing would be quite alarming on the bumpy roads of GB today if left alone.
I remember dealing with similar problems on the GRP body of a clan crusader I rebuilt years ago so am comfortable with the idea of getting the right thickness of GRP for the balance of strength and flexibility, if that's all that is commonly employed .
RichC the Newby (for now)
RichC - Fourth Gear
RichC, any chance of a photo of the fibreglass split. By chassis mounting plate, do you mean the rear extension of the chassis horizontal section (aft the curved tubes)?
I think the chassis "plate" is more than adequate here. Most probably all that is needed is a competent repair of the GRP. Both to restore the original shape (ie support the existing sagging) and to restore strength. Is it possible to ascertain how the damage originated. My boot floor damage was almost certainly caused by PO, reversing exhaust pipe into external obstruction, with the silencer mounts taking the damage.
Gerry
Gerry
- gerrym
Hi Rich
Holes in boot floors seem common due to broken donuts causing the shaft to fly through the boot floor.
See elan-plus-f13/boot-floor-fibreglass-repairs-pop-rivets-t16428.html
for some impressive repairs.
Jason
Jason
Jason1 - Coveted Fifth Gear
Hi jason,
thanks for the link to the scary stuff. I feel empowered to tackle it properly now. ( well maybe not RIGHT now , but sometime in the summer ...
cheers, & thanks again for your help.
p.s. I'm pretty sure you may have heard of the old trick for unseizing clutchplates , but just in case, I've found that selecting 4th gear , depressing clutch pedal and turning over ignition has worked for me. You'll hear the bang as the starter motor clears the plate from flywheel...
Rich C
Rich C
RichC - Fourth Gear
Hi Rich
Yes tried that at the weekend but with limited spare it is a bit hairy.
Jason
Jason
The good weather over the bank holiday allowed me to get down to it!
first picture shows the splits from beneath
And with all the cosmetic surgery pictures I'll show you the sagging bottom BEFORE and AFTER
likewise from the other side
and after treatment .
RichC
RichC
RichC - Fourth Gear
