Another early +2 bites the dust
• Page 4 of 4 • 1, 2, 3, 4
davidj wrote: To be honest I would prefer no sunroof at all. I only fitted it as it came with an awful glass sunroof!
David
I have the same issue, my car has an aftermarket glass sunroof. I think I'm going to fit a new roof panel during the restoration.
dusty - Third Gear
[quote][/quote] see another early car has been broken up - Unless the owner has resurrected it with a different shell perhaps
http://cgi.ebay.co.uk/Lotus-Elan-2-Body ... |294%3A100
the quote in the above post was meant to refer to this shell currently on e-bay
brian
brian
- ncm
I saw two more tubs in Blackburn today, one looked like a scrapper, the other one DOY 100J looked good.
I was there to look at window frames and got one....but I also had a look at the Lucas rectangular lights that came off one of them. They were rough and looked like they needed a lot of work, which leads to this question I have been chewing over all morning:
Should i just fill the holes in the valances? They look better without the fog / spots to me. They seem expensive to sort or replace and then I have to make the decision as to how I want them to function and how I want them to be switched on, then pay someone to wire them up as per my wishes. And then they need maintaining. Oh, and they must have weighed a bag of sugar each.
Do early Elan owners ever wish they had the extra power now and again? Have I missed a thread on this dilemma somewhere? I am going to the spray shop tomorrow and need my executive decision by then!!
I am now an ex-Elan owner but will drop by from time to time with some suitably inappropriate comments.
richgilb - Third Gear
Rich,
How keen are you on authenticity? I assume that your car has holes in the valance that uses to contain the plastic liners that sat behind the fog and spot lights. On that last cars (130 on?) the light recesses were moulded into the valance so there was no hole.
I've modified my earlier car to add the recesses (moulded off the plastic liner) as I want the look of the lights. It should be easy to fibreglass from the inside and finish off with a smooth valance, the choice is really yours.
- mikealdren
Yes, I have two holes where the Lucas lights used to be. Not too bothered about authenticity....as long as the mods don't look like chavvy Halfords stuff, I am happy to personalise my car.
I am surprised to hear that you prefer the +2 with the lights? Most people seem to prefer the earlier look. I was more worried about the pracical side of things...i.e. not having lighting options.
Brian, Ref the boot release. There was a "series 1.5" elan +2 (my words, not lotus) which gained the internal boot release, centre exhaust, later door handles etc However, it is not an "s" therefore is still an early car. I think it was introduced around serial number 750ish (don't have the workshop manual to hand)
I guess the side lights must have been an option on the early cars as it appears to be pot luck if you have them fitted or not!
David
David
- davidj
jason,
just having had another look at this thread i noticed a glaring difference between your pedal box and mine . the spacer on mine was behind the clutch master cylinder & i believe i was the first person to have removed it. there was no spacer behind the brake master cylinder .
your spacer is behind the brake master cylinder! ??
maybe they used different length pushrods behind?
RichC
RichC
RichC - Fourth Gear
Users browsing this forum: smiths everest and 19 guests
