Re: Which of these S2 Europa parts will fit an elan plus 2
Posted: Mon Apr 13, 2009 6:00 pm
There's a lot of dodging around the lens question. There are three lens variants in the same form factor that I'm aware of:
All red (Jaguar)
Red with white backup lights (Europa S2 and Twincam Federal)
Red with white backup and yellow (is it brake or tail?) (Europa S2 and Twincam European)
The second two variants were used in some Elans.
Option 1 is commonly available from British parts suppliers
Option 2 can be sourced new from a friend of Steve Veris' (see the Europa list referenced above)
Option 3 can be sourced from Banks (and others, I'm sure).
S1 Europas used the Lancia assembly. Nobody who has one will sell it to you accidentally.
I understand front bumper is the same, would be surprised if even mounts were different 'cause it was outsourced originally.
Rear bumper, no way!
Steering wheel fits. All cars used the Spitfire column (at various MK levels over the years). But since the Spit ones you'll find are likely ugly, you're much better off finding the wheel you want and getting a Grant or other adapter to make it fit the Spit splines. I believe all TR's use the same splines, so you're not limited to Spit-GT6 here (though they're all still ugly.)
All red (Jaguar)
