Re: Lotus 2litre into a +2, does it go?
Posted: Fri May 02, 2008 2:26 pm
robcall wrote:mikealdren wrote:Russ,
As to the origins of the 907, it was originally based on the Vauxhall engine. Rob, I think you're unfair describing it as a Van engine. Although it was used in the CF van, it was primarily used in the cars (Victor, Magnum, Viva, Victor Firenza etc). Commercial factors led to Lotus eventually casting their own blocks and taking it all in house. Vauxhall then brought out its own twin cam head and had great success in rallying (Firenza and Chevette HS) although, if I remember correctly, they also got caught using Lotus heads at one point!
Only to the extent that Lotus did their head testing in Bedford vans.
Do you have a reference to the 907 being based on the Vauxhall engine?
All mine show the block only being used to test the Lotus head!
Have a look at this from Hugh Haskell's book Colin Chapman Lotus Engineering
Sean
