Lotus 2litre into a +2, does it go?
• Page 3 of 3 • 1, 2, 3
robcall wrote:mikealdren wrote:Russ,
As to the origins of the 907, it was originally based on the Vauxhall engine. Rob, I think you're unfair describing it as a Van engine. Although it was used in the CF van, it was primarily used in the cars (Victor, Magnum, Viva, Victor Firenza etc). Commercial factors led to Lotus eventually casting their own blocks and taking it all in house. Vauxhall then brought out its own twin cam head and had great success in rallying (Firenza and Chevette HS) although, if I remember correctly, they also got caught using Lotus heads at one point!
Only to the extent that Lotus did their head testing in Bedford vans.
Do you have a reference to the 907 being based on the Vauxhall engine?
All mine show the block only being used to test the Lotus head!
Have a look at this from Hugh Haskell's book Colin Chapman Lotus Engineering
Sean
Foxie - Coveted Fifth Gear
Here's the 907 engine in a lotus7.
http://vrd.snagroup.com/Lotus7_1.htm
Nigel Robertson
robcall - Third Gear
Great reference Sean!
I'd still describe the all-alloy Lotus built 907 as a Lotus engine
As an example I had a small oil leak from the distributor in the Excel.
The seal is a Lotus only part! It was cheaper to have the distibutor modified to accept a reguar sized seal than place a Lotus one!
Nigel Robertson
robcall wrote:Great reference Sean!
Yes, of course it's a Lotus engine, just as the Ford 1500 was transformed into the Twincam.
The magical ingredient is that Chapman's genius has been added !
Sean
Ehh-no!-to be specific thats the Lotus-Ford Twincam!
You won't Vauxhall or Ford or Isuzu or Toyota or anything else stamped on the 907 castings!
Heres an article that answers both sides
http://www.belchamber.org/techhistory.html
Nigel Robertson
Yes, very informative article on the Lotus 907 engine and its origins.
Sean
