The abridged saga of my Europa lunacy
• Page 5 of 5 • 1, 2, 3, 4, 5
Thanks guys! Here is the latest.
I have been machining the Zetec flywheel to accept the Renault clutch. I need to make a pilot bearing and throwout bearing extension.
I machined a thermostat housing that clears the bellhousing, I still need to add the sensor and heater hose takeoffs.
The brake set up is getting closer. I am working on the front hubs currently.
Chuck Nukem - Second Gear
mbell wrote:Looking like very good progress. Rolling chassis ready for the body by the new year?
I hope so!
Mazzini wrote:Fabulous!
Thank you!
Flywheel is officially mated to the clutch. I got it drilled, tapped, and pinned for the Renault clutch plate and disc. The indicator said I had it concentric to at least .0005" I will have it balanced as an assembly with the plate after I remove another lump of mass off the backside. For now the task is to make the TO and Pilot bearing extensions...then the wheels go on!
I also purchased a new donor car.... I had planned to use the ordinary Zetec. To my knowledge the SVT/ST170 engine has not been used in a Europa before. I have heard of them being fitted to 7's and +2's. With a normal Zetec, part of the europa problem centers around the fact the intake manifold interferes with the frame. The common route is to run ITB (with SVT lower intake) and I had prepared to go this route with a standalone ECU. Then this shining beauty came in to my life...complete with a bad fuel pump and burned up clutch. The thought occurred to me that the different SVT intake might just fit... It is a gamble but I am prepared to sacrifice all my resources to the cause. If it works I can use the factory harness, ECU, etc. This motor even comes with headers, though I suspect they will need to be re routed...FOR SCIENCE!
