Replacement Fuel Tank
First off, this is a note of advice and in no way is it a criticism of any supplier. I bought an Aluminium petrol tank, gasket and sender unit a few months ago. As it is now assembly time I ordered the screws and 3mm diameter nylon washers. I looked over the tank and noticed the tapped holes were a bit larger than 3mm. I fitted an M5 screw into the tapped holes. I mentioned this to the supplier and he confirmed that the tank is tapped M5 but the screws and washers are for the original OEM tank design and are smaller in diameter. The suppliers are reallly helpful and are sending the correct sized items so all is well. Just be aware that sometimes small details can change on replacement parts.
Al
Al
- RAJ2628
I think I could write a novel about replacement parts that don't match/fit/assemble like what was originally in my car. I'm glad you were able to get it sorted out.
1967 Lotus Elan Coupe - Super Safety
2019 Tesla Model 3 Performance
1973 Ford F100 4x4
1973 Ford F100 4x4
MrBonus - Second Gear
Well I have come now to not expect any part I buy regardless of supposed origin and whichever of the suppliers I get it from to actually just fit as it is supposed to.
Everything I buy seems to need fettling or altering in order to make it fit...Seems to be the norm unfortunately!
Alan.
Alan.
'71 +2 S130/ 5speed Type9.
- alanr
Actually, the original studs fastened to the original tank are 1/4-28 fine thread, which is larger than either 3mm or 5mm and they accept 1/4-28 nylok nuts which then hold the tank in place.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
