Lotus Elan
Oil drain Twin Cam & BDA. Can be fitted without head removal
PostPost by: holywood3645 » Sat May 30, 2020 6:16 am
Good friend is making these. I’m posting on his behalf.
Precision piece of machining, not
6803C010-096E-43A4-9B0B-4ED04AF70C8E.png and
a mass produced or cast lump
$150 (-10%) if your on this list.
James
58BB0DB4-055E-4821-846D-4BEED3D67332.jpeg and
PostPost by: Andy8421 » Sat May 30, 2020 11:56 am
While it is a thing of beauty, I am not sure Colin would have approved.
5 'O' rings and lockwire would struggle to meet his value engineering principles.
PostPost by: nmauduit » Sat May 30, 2020 12:13 pm
Andy8421 wrote:While it is a thing of beauty, I am not sure Colin would have approved.
Yes, I must say I'm a bit puzzled by the bottom one, resting on raw cast iron of the bossing of the fuel pump opening, which is not even flat and square to the pump flange...
S4SE 36/8198
PostPost by: avro » Sat May 30, 2020 1:09 pm
lt certainly looks to be a nicely engineered product but there is a knack of fitting a new original rubber drain tube without having to remove the cylinder head . It just requires a large mug of boiling water.
New drain tubes are not very pliable but a soak in boiling water for a couple of minutes makes them very supple.
With a quick dry off before they cool down too much, some silicone sealant applied to the mating surfaces of both ends and you can then push the bottom into place first and then with some pressure using both thumbs the top will slide across the underside of the head an pop into place . Rotating the tube slightly will then spread the sealer more evenly. When cool the tube does not lose any of its original dimensions .
Nick
avro
PostPost by: bitsobrits » Sat May 30, 2020 2:33 pm
So what prevents oil wicking down the threads?
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: holywood3645 » Sat May 30, 2020 3:15 pm
Maybe this will help answer.
The fixed shoulder sits on the top of opening at fuel pump
Tha adjustable sholder is not threaded. It has a interference fit with 2,recessed O rings.
It is pushed up in place with the knurled nut that has a 3rd O ring between it and the shoulder.
I fitted the safety wire to mine, however it’s not on the original.
I will ost a couple more pictures.
Fitting:, back of knurled nut, drop adjustable shoulder, place threaded end in top opening at head, slide bottom on top op pump opening, slide adjustable shoulder back up to head, then back up adjustable knurled nut to secure. Easy instal.
As far as what Colin would say.., Please ask and let me know, as he isn’t replying to my calls... ;-)
James
PostPost by: Fred Talmadge » Sat May 30, 2020 4:20 pm
There is a cheaper option, the VW pushrod tube repair kit I used it when I put the head on without the return fitting. You have to cut it to length, but it works fine.
https://www.youtube.com/watch?v=UqxcPG2ZB-Y
Fred Talmadge
PostPost by: el-saturn » Sat May 30, 2020 4:34 pm
.mine...was...similiar,..howewer...2...o-rings..........................sj
